Old 06-01-2011, 12:21   #1 (permalink)
Member: 1559039
Nokia 5230 Not a SL3 phone?
I have read this 5230 with 3.5 rev00 and bruteforce it no code found
Phone Type: RM-588 (Nokia 5230)
SW Version: V ICPR72_10w21.3.1 08-09-10 RM-588 (c) Nokia
Imei plain: 35535304849630-5
Product Code: 059D2N4
Battery voltage: 4140 mV, current: 79 mA
ApeCoreSw: V 21.0.102
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355353048496305
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2340000100000000
PROFILE_BITS: 8000000000000000
BLOCK1: 1=CLOSED(MCCMNC), DATA=23430F [United Kingdom-T-Mobile UK ], 2=CLOSED(GID1), DATA=23430F [United Kingdom-T-Mobile UK ]
Backup already exist.
MXKEY Serial: [FT SCR2000 0] - C08xxxxx
Using device: HTI BOX, FW ver: 00.08
Driver: FTDIBUS, ver: 2.4.16.0, NTMP ver: 2.6.0.0
Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
Product: V ICPR72_10w21.3.1 08-09-10 RM-588 (c) Nokia
Using cached productData[07900013BBA500523DB04164F5DA31E37E45DF7E] ...
Hash file saved to: C:\mobileEx\3.5\data\SL3\355353048496305.sha
You can use this file to resume bruteforce task.
And now read with 3.5 rev10 and I've got this:
Battery voltage: 4117 mV, current: 96 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Driver: FTDIBUS, ver: 2.4.16.0 , NTMP ver: 2.6.0.0
Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011)
ERROR: Not a SL3 phone.
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 07900013BBA500523DB04164F5DA31E37E45DF7E
ASIC MODE ID: 00
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
TransmissionMode: DDR&TX2
FlashID0: 0400 0000 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT
FlashID2: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,CMT
ALG [35]: XSR 1.6
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.10.0 revision: 2.0 size: 0x875B6
CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15
Reading PASUBTOC ...
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Please if any one have sugestion?
Old 06-07-2011, 11:17   #2 (permalink)
Member: 67805
Thanks Meter: 334
I have same phone 5230 and same info PA_SIMLOC30
Is this 20 digits nck?
The Following User Says Thank You to MOBICOM For This Useful Post:
Old 06-07-2011, 11:39   #3 (permalink)
dualsimcect's Avatar
Member: 72330
Sonork: 100.1604259
Thanks Meter: 35
conect on usb and click scan,maybe will help
The Following User Says Thank You to dualsimcect For This Useful Post:
Old 06-07-2011, 11:53   #4 (permalink)
Member: 1589308
yes its right solution
The Following User Says Thank You to RAJATELECAM For This Useful Post:
Old 06-07-2011, 13:41   #5 (permalink)
Member: 1559039
I've try with usb same thing but with atf quickly show 20-digit NCK
Case close.
Thanks all for reply
BR.Lechu
Page generated in 0.25473 seconds with 8 queries
