Old 01-05-2012, 13:02   #1 (permalink)
Member: 982335
Thanks Meter: 202
Nokia 5230 only VIBRATE.... (ANSWERED)
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C080****
Using device: HTI, FW ver: 00.50, SN: 0000****
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 11B00112FE8F00528DE833CB9DBB40BBBC213C5D
ASIC MODE ID: 00
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [***] version: 11.34.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
e***ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15
Processing MCU file: RM-588_51.0.002_prd.core.C00
[***,XSR 1.6] size: 106.66 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 158.19 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: Status reported bad blocks.
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent
CMT SOS*UPDAPP block sent
CMT SOS*ENO block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
NAND: OK
Programming completed in 4 min 50.188 s
Processing PPM file: RM-588_51.0.002_prd.rofs2.V21
[***,XSR 1.6] size: 12.14 MB
Erase size: 33.50 MB
CMT FLASH,MuxOneNAND area [06FE0000-0915FFFF]
NAND: OK
CMT SOS+ROFS2 block sent
NAND: OK
Programming completed in 34.188 s
Processing PPM file: RM-588_51.0.002_C01_prd.rofs3.fpsx
[***,XSR 1.6] size: 6.16 MB
Erase size: 13 MB
CMT FLASH,MuxOneNAND area [09160000-09E5FFFF]
NAND: OK
CMT SOS+ROFS3 block sent
NAND: OK
Programming completed in 17.437 s
Processing CNT file: RM-588_51.0.002_000_001_U001.uda.fpsx
[***,XSR 1.6] size: 18.56 MB
Erase size: 86.12 MB
CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF]
NAND: OK
NAND: OK
Programming completed in 53.453 s
Total time for flashing process(boot+erase+write) was 6 min 46.062 s
Need help.
Old 01-05-2012, 14:07   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
please apply QUick FIx > *** RAP3NAND Erase
Old 01-05-2012, 14:13   #3 (permalink)
esn_123's Avatar
Member: 94184
Thanks Meter: 94
flash same product code
Old 01-05-2012, 22:06   #4 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
flash with latest version then do bb5 quick fix bro....
br
Old 01-07-2012, 06:30   #5 (permalink)
Member: 982335
Thanks Meter: 202
Got error while quick fix...
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
eBB5ProtocolType: NEW
S***ested algorithm: XSR 1.5
FUR: Adding Asic CMT as client...
Failed to add FUR client
Old 01-07-2012, 09:59   #6 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 523
chek bt ic change 100% your problem solve
Page generated in 0.23425 seconds with 9 queries
