09-10-2011, 11:49 | #1 (permalink) |
Freak Poster Join Date: Jul 2011
Member: 1619487 Status: Offline Thanks Meter: 2 | nokia 5230 unlocking? MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1AC0000DEF8E00528A51F34F9D5F1E0A10C1B7C2 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.24.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.24.0 revision: 2.0 size: 0x87D1A Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Original Imei: 35201404190831 Original Product code: 059B139 Bluetooth ID: 0CDDEFCDADA9 SIMLOCK PA identifier: [0] PA_SL3 Phone type: RM-588 (Nokia 5230) SW version: V ICPR72_09w36.10 30-10-09 RM-588 (c) Nokia Imei plain: 35201404190831-5 Product code: 059B139 Battery voltage: 4154 mV, current: 215 mA ApeCoreSw: V 11.0.079 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352014041908315 Version: SIMLOCK SERVER Provider: Telefónica Móviles España, SAU , Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140700000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=21407F [Spain-Telefónica Móviles España, SAU ] BLOCK2: 1=CLOSED(MCCMNC), DATA=21402F |
09-10-2011, 12:24 | #2 (permalink) | |
Moderator Join Date: Dec 2010 Location: Malaysia
Member: 1464783 Status: Offline Thanks Meter: 1,091 | Quote:
yes if you have super pc | |
09-10-2011, 16:14 | #4 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Edge of the world
Member: 492380 Status: Offline Thanks Meter: 184 | This phone is SL3, and the only solution to unlock is using bruteforce method. bruteforce method is using your GPU (graphic procesing unit) or VGA card memory to do its job. So you need to buy a supported VGA card (high end VGA card) to do this unlock process. Try to search this forum for more info. |
10-09-2011, 09:32 | #5 (permalink) |
Junior Member Join Date: Jun 2011
Member: 1590481 Status: Offline Thanks Meter: 0 | Please help me to Unlock my Nokia 5230-1C Phone Locked by T-Mobile USA, Info are attached by message Service Provider: T-Mobile USA Model: 5230-1c IMEI Number: 359341032827110 FCCID: LJPRM-593 IC: 661E-RM593 Type: RM593 Code: 0592823ER04r1N Made In Mexico |
10-09-2011, 09:50 | #6 (permalink) | |
No Life Poster Join Date: Sep 2003 Location: Right There ( Croatia )
Member: 38150 Status: Offline Sonork: 100.1611516 Thanks Meter: 143 | @sam.garchia Quote:
Two way is for unlock this phone but need to spend some money Find Some remote server and ask for code by IMEI (cheaper if you dont have so much phone ) Invest some money and make your OWN LBF machine and calculate code for unlock Need Some VGA wich cost some $$$ Regrads Mario | |
12-10-2011, 19:32 | #7 (permalink) |
Major Poster Join Date: Mar 2011 Location: Spain Age: 50
Member: 1530448 Status: Offline Sonork: 1608821 Thanks Meter: 2 | Imei net: 356051035541252 Version: SIMLOCK SERVER Provider: Vodafone España, SAU , Country: Spain Counter: 0/3, 0/10 CONFIG_DATA: 2140100000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=21401F [Spain-Vodafone España, SAU ] BLOCK2: 1=CLOSED(MCCMNC), DATA=21401F [Spain-Vodafone España, SAU ] Backup already exist. MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085683B Connection status: EHCI:HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.70 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Phone type: RM-588 (Nokia 5230) SW version: V ICPR72_10w04.5 22-03-10 RM-588 (c) Nokia ApeCoreSw: V 20.0.005 Using cached productData. PUBLIC ID: 23200104428300529C41A452309D87C4DEAF9690 PRIVATE ID: B7C77BC1BD177E729664E20ABCBC47C42A41C570 #pw+ 081223155540040 +1 # #pw+ 436585161657298 +2 # #pw+ 736407406922918 +3 # #pw+ 688357610444206 +4 # #pw+ 012485387934262 +5 # #pw+ 598610754461136 +6 # #pw+ 988396668805138 +7 # Nokia 5230 USB Phonet detached. New device connected: nmwcdc\Nokia 5800 XpressMusic USB Phonet Connection status: EHCI:HUB:USB 2.00 High-speed Nokia 5800 XpressMusic USB Phonet ready. Nokia 5230 USB Phonet detached. BUT DOSEN´T WORK THATS CODES, WHAT I CAN DO? |
12-10-2011, 20:29 | #8 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Spain
Member: 840762 Status: Offline Thanks Meter: 166 | The Nokia 5230 is a SL3 phone! You can not direct unlock! Just reading HASH and calculating with your super pc or paying a server to calculate it for you... Read a little before posting, Best regards! |
