Old 11-29-2011, 13:05   #1 (permalink)
Member: 60993
Thanks Meter: 22
nokia 5233 phone startup failed contact retailer
i have nokia 5233 it show phone startup failed contact retailer
i try full flash & pmm auth 1 to 309
but it will show phone startup failed contact retailer
pls help me it(urgent)
Old 11-29-2011, 13:34   #2 (permalink)
Member: 700741
Sonork: 100.1617188
Thanks Meter: 409
where is log file............
Old 11-29-2011, 13:37   #3 (permalink)
smarty3399's Avatar
Member: 1038860
Sonork: 100.1593889
Thanks Meter: 173
http://forum.gsmhosting.com/vbb/f613...ection-967354/
Smarty3399
Old 11-29-2011, 17:12   #4 (permalink)
Member: 60993
Thanks Meter: 22
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0A100104488C0052B8A71C91E72AECA306A8C5C5
ASIC MODE ID: 00
ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15
Original Imei: 358**************
Original Product code: 0594741
Bluetooth ID: C8979F893CB9
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Phone type: RM-625 (Nokia 5233)
SW version: V ICPR72_11w10.3 24-03-11 RM-625 (c) Nokia
Imei plain: 3583*********-5
Battery voltage: 4632 mV, current: 171 mA
ApeCoreSw: V 50.1.001
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 3583**********
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
pls help me
Old 11-29-2011, 19:01   #5 (permalink)
shybet's Avatar
Member: 492380
Thanks Meter: 184
Don't see any problem in your posted log.
Check hardware, could be hardware problem.
Old 11-30-2011, 05:57   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
form scan logs seems all OK.
start sef test, and post here the logs.
but my feeling, you got error on avilma.
Old 09-23-2012, 10:47   #7 (permalink)
Misbahullah's Avatar
Member: 938983
Sonork: 100.1585802
Thanks Meter: 102
5233 RM-625 Phone startup failed contact retailer with the logs this is after flashing logs
Phone type: RM-625 (Nokia 5236)
SW version: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia
ApeCoreSw: V 51.1.002
Imei plain: 35626404048178-2
Product code: 059B7L6
Battery voltage: 3663 mV, current: 286 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 356264040481782
Counter: 0/3, 0/10
and this is self test log after running all
Phone Type: RM-625
ID Test name Startup Result
88 TAHVOINT Y passed
46 UEM_CBUS_IF Y passed
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
33 SIM_LOCK N passed
93 SECURITY N passed
90 PWR_KEY N passed
2 CURRENT_CONS N passed
20 BACKUP_BATT N passed
42 RADIO N passed
96 HOOKINT N passed
101 BTEMP N passed
8 MBUS_RX_TX_LOOP Y passed
119 IIC N passed
117 DIGIMIC N passed
108 EXT_DEVICE N passed
56 CDSP_SLEEPCLK_FREQ N passed
128 CDSP_SLEEPCLOCK_FREQ N !no signal
86 CDSP_RF_BB_IF N !no signal
83 CDSP_RF_SUPPLY N !no signal
85 CDSP_TX_IQ N !no signal
74 CDSP_TXC_DATA N !no signal
79 CDSP_RX_PLL_PHASE_LOCK N !no signal
80 CDSP_TX_PLL_PHASE_LOCK N !no signal
81 CDSP_RX_IQ_LOOP_BACK N !no signal
77 CDSP_GSM_TX_POWER N !no signal
21 LPRF_IF N passed
22 CAMERA_IF N passed
5 CAMERA_ACCELERATOR N passed
44 LPRF_AUDIO_LINES N !no signal
59 MAIN_LCD_IF N passed
60 TOUCH_STUCK N passed
71 BT_WAKEUP N passed
103 TOUCH_IF N passed
104 ACCEL_IF N passed
113 LCD_CONTROLLER N passed
49 VIBRA N passed
91 USB_LOOP N !NOT EXECUTED(03)
42 RADIO N !NOT EXECUTED(03)
Old 09-23-2012, 10:49   #8 (permalink)
Member: 938983
Sonork: 100.1585802
Thanks Meter: 102
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Phone Type: RM-625
90 PWR_KEY N passed
42 RADIO N passed
96 HOOKINT N passed
101 BTEMP N passed
119 IIC N passed
21 LPRF_IF N passed
49 VIBRA N passed
Old 09-23-2012, 10:53   #9 (permalink)
Member: 911426
Thanks Meter: 78
SIMLOCK_TEST passed
Logs is ok, might be hardware problem..
Old 09-23-2012, 11:35   #10 (permalink)
Member: 161280
Sonork: 100.1616990
Thanks Meter: 82
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Phone Type: RM-625
90 PWR_KEY N passed
42 RADIO N passed
96 HOOKINT N passed
101 BTEMP N passed
119 IIC N passed
21 LPRF_IF N passed
49 VIBRA N passed
have you my friend try to format your phone?
Old 09-23-2012, 14:57   #11 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
dear i face same problem my problem is solved use original battery
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post:
Old 12-15-2012, 08:21   #12 (permalink)
Member: 363265
Sonork: 100.1648064
Thanks Meter: 65
bro just check BSI ways...... if BSI open make a jumper ....... i allready solve my problem....
The Following 2 Users Say Thank You to mobilecare_786 For This Useful Post:
Old 12-30-2012, 08:07   #13 (permalink)
Member: 272979
Sonork: 100.1607215
Thanks Meter: 135
just chk the bsi line from the battery connector
The Following 2 Users Say Thank You to feel_free For This Useful Post:
Old 01-06-2013, 10:11   #14 (permalink)
MUKESH RAJ's Avatar
Member: 1084080
Thanks Meter: 8,114
here is b/c ways -
The Following 2 Users Say Thank You to MUKESH RAJ For This Useful Post:
Old 01-06-2013, 10:13   #15 (permalink)
MUKESH RAJ's Avatar
Member: 1084080
Thanks Meter: 8,114
Page generated in 0.24617 seconds with 9 queries
