Old 11-05-2012, 10:00   #1 (permalink)
reset12345's Avatar
Member: 694652
Sonork: 100.1669706
Thanks Meter: 193
nokia 5233 softwher ok but pone not on ?????
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0854362
Using device: HTI, FW ver: 00.50, SN: 00001A38
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1D000108008F0052ABEFE41E20EBA3A0FA99BC79
ASIC MODE ID: 00
ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 9.50.0 revision: 2.0 size: 0x70C62
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15
Original Imei: 35832103509859
Original Product code: 0594743
Bluetooth ID: C8979F75E717
SIMLOCK PA identifier:
[0] PA_SIMLOC30
Phone type: RM-625 (Nokia 5233)
SW version: V ICPR72_10w42.2 26-11-10 RM-625 (c) Nokia
ApeCoreSw: V 40.1.003
Imei plain: 35832103509859-7
Battery voltage: 4688 mV, current: 139 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 358321035098597
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 11-05-2012, 10:19   #2 (permalink)
VC_INDIA's Avatar
Member: 1236722
Sonork: 100.1601546
Thanks Meter: 2,126
flash with same product code then post result
Old 11-05-2012, 10:33   #3 (permalink)
reset12345's Avatar
Member: 694652
Sonork: 100.1669706
Thanks Meter: 193
not solve ..........................any one helf me ?????
Old 11-05-2012, 10:48   #4 (permalink)
VC_INDIA's Avatar
Member: 1236722
Sonork: 100.1601546
Thanks Meter: 2,126
take backup simlock or rpl
u need erase this phone full
then flash after flash restore imei or simlock
Old 11-05-2012, 11:42   #5 (permalink)
Absar_Global's Avatar
Member: 1442705
Thanks Meter: 736
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
[0] PA_SIMLOC30
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
bro.check bsi line.............................................. ..................
Old 11-05-2012, 12:09   #6 (permalink)
reset12345's Avatar
Member: 694652
Sonork: 100.1669706
Thanks Meter: 193
bsi line ok .........................
Old 11-05-2012, 12:11   #7 (permalink)
.::GEANECIV::.'s Avatar
Member: 853097
Sonork: 100.1622287
Thanks Meter: 129
check ur battery bro
Old 11-05-2012, 12:20   #8 (permalink)
reset12345's Avatar
Member: 694652
Sonork: 100.1669706
Thanks Meter: 193
battery ok on,off swich ok i cheeked
Old 11-05-2012, 12:21   #9 (permalink)
reset12345's Avatar
Member: 694652
Sonork: 100.1669706
Thanks Meter: 193
full flash but sme proublum log here
Version from phone: 40.1.003
Version from file: 51.1.002
Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35832103509859_BA CK.rpl).
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80
Suggested algorithm: XSR 1.6
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B49D
Processing MCU file: RM-625_51.1.002_prd.core.C00
[BB5,XSR 1.6] size: 95.97 MB
Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 158.19 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: Status reported bad blocks.
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent
CMT SOS*UPDAPP block sent
CMT SOS*ENO block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 4 min 20.125 s
Processing PPM file: RM-625_51.1.002_prd.rofs2.V21
[BB5,XSR 1.6] size: 12.04 MB
Erase size: 36.50 MB
CMT FLASH,MuxOneNAND area [06CE0000-0915FFFF]
NAND: OK
CMT SOS+ROFS2 block sent
NAND: OK
Programming completed in 33.765 s
Processing PPM file: RM-625_51.1.002_C01_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 6.16 MB
Erase size: 13 MB
CMT FLASH,MuxOneNAND area [09160000-09E5FFFF]
NAND: OK
CMT SOS+ROFS3 block sent
NAND: OK
Programming completed in 17.297 s
Processing CNT file: RM625_51.1.002_000_001_U001.uda.fpsx
[BB5,XSR 1.6] size: 17.07 MB
Erase size: 86.12 MB
CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF]
NAND: OK
NAND: OK
Programming completed in 48.781 s
Total time for flashing process(boot+erase+write) was 6 min 10.984 s
SW version: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia
ApeCoreSw: V 51.1.002
Battery voltage: 4688 mV, current: 189 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 1.922 s
Old 11-05-2012, 13:25   #10 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,261
Hi,
Backup RPL All Section, Full PM & Simlock.
Use Erase Method from here: HTI On USB, what this box can do?,
Download same Product of Version 40.1.003,
Flash & Restore PM, IMEI & Simlock,
Make Reset All & Post reply.
Have a good day.
BR,
ZUBER
Flash with
Page generated in 0.30525 seconds with 7 queries
