07-18-2011, 12:13 | #1 (permalink) |
Insane Poster Join Date: Jun 2007 Location: portugal Age: 56
Member: 528246 Status: Offline Thanks Meter: 4 | Nokia 5530 XpressMusic ___SECURITY_TEST failed! Phone Type: RM-504 (Nokia 5530 XpressMusic) SW Version: V ICPR72_10w25.3 11-10-10 RM-504 (c) Nokia Imei plain: 35825303833074-5 Product Code: 0583839 Battery voltage: 4785 mV, current: 166 mA ApeCoreSw: V 32.0.007 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 358253038330745 Version: SIMLOCK SERVER Provider: TMN - Telecomunicaçôes Movéis Nacionais, S.A. , Country: Portugal Counter: 0/3, 0/10 CONFIG_DATA: 2680600000000000 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=26806F [Portugal-TMN - Telecomunicaçôes Movéis Nacionais, S.A. ] MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - CXXXXXX Using device: HTI BOX, FW ver: 00.17 Driver: usbohci:usbhub:usbccgp:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17841(12-07-2011), Library ver: 1.0.0.11875(12-07-2011) Product: V ICPR72_10w25.3 11-10-10 RM-504 (c) Nokia ApeCoreSw: V 32.0.007 Using cached productData. PUBLIC ID: 1E300104318800527DAFF1FE3E0337E26CDCF8BB PRIVATE ID: 7F36FC029C75F2A9846EC938451266E33AB361ED E-FUSE: 0514B352 SEC ROM CRC: 3E691FF8 ERROR: read packet failed or calculation failed (status: 0) KEN ENYONE EXPLAIN IF POSSEBLE TO FIX???? |
07-18-2011, 12:21 | #2 (permalink) |
Junior Member Join Date: Aug 2007 Location: Philippines
Member: 575629 Status: Offline Thanks Meter: 11 | try this solution.. back up all first then go to service tab pm then check load rfbb from server after checking then click write... wait until finish and your done... post result... |
07-18-2011, 13:04 | #3 (permalink) | |
Member: 528246 Status: Offline Thanks Meter: 4 | Quote:
NK applet version: 00.20 NK module ready. Please "Scan" or "BUS check" before any operation ... STANDALONE MODE enabled. Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 Authenticating using security server ... Connecting to server[main2.mxkey.biz] ...Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 Authenticating using security server ... Connecting to server[main2.mxkey.biz] ...Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main2.mxkey.biz] ...Connection timed out Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 89.180.120.37 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 34 (80 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Completed in 1.391 s Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 Authenticating using security server ... Connecting to server[main2.mxkey.biz] ...Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main2.mxkey.biz] ...Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 Authenticating using security server ... Connecting to server[main2.mxkey.biz] ...Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.7 Authenticating using [MX] security server ... Connecting to server[main2.mxkey.biz] ...Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request | |
07-19-2011, 10:42 | #5 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | Quote:
when phone goes to auth on server then press write , without auth on server if you write pm then you get failed every time | |
07-21-2011, 13:48 | #6 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Udalguri, ASSAM
Member: 300547 Status: Offline Thanks Meter: 23 | yes! i have this solution 1. first backup rpl ( go *gt; imei and security tab *gt; imei rebuild *gt; backup rpl) 2. erase old pm ( go *gt; pm tab *gt; erase ) 3. Reset npc data ( go*gt; imei and security tab*gt; reset NPC data)( must backup rpl before do this) 4. Erase pm again (go *gt; pm tab *gt; erase ) 5.Write rpl from backup ( go *gt; imei and security tab *gt; imei rebuild *gt; restore imei) 6. go pm tab *gt; super sd auth or pmm auth *gt; than write good or modified pm ( must need pm 1 *amp; 309) 7. erase pm again 8. Recover CERT ( go*gt;imei and security tab*gt; imei rebuild *gt; recover cert) 9. give full factory reset then enjoy |
07-22-2011, 07:16 | #8 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Middle East
Member: 950386 Status: Offline Thanks Meter: 114 | You can write full pm or you can do what Bee Squad has mentioned. When security area has failed this normally means you have damaged PM and it needs to be restored or repaired. Kind Regards |
03-30-2012, 12:42 | #9 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: Armenia Age: 38
Member: 888943 Status: Offline Sonork: 100.1615584 Thanks Meter: 239 | Quote:
