Member: 1051835
Sonork: 100.1594332 Thanks Meter: 514 | Nokia 5800 not boot after flash Hi,
Nokia 5800 cannot boot after flash,
Here is log Quote:
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: xxxxxxx
Using device: USB ROM and HTI, FW ver: 00.50, SN: xxxxxxx
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Processing MCU file: RM-356_52.0.101_prd.core.C00
[BB5,XSR 1.5] size: 108.08 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 18700017919300529D5E8CC0401CD91DF4EA3DF5
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped.
CMT PAPUBKEYS is blank/erased.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 158.19 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 76A20187 [RAP Certificate 106 v1] sent
CMT SOS*UPDAPP block sent
CMT SOS*ENO block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 1 min 48.140 s
Processing PPM file: RM-356_52.0.101_prd.rofs2.V01
[BB5,XSR 1.5] size: 24.38 MB
Erase size: 31.87 MB
CMT FLASH,MuxOneNAND area [07180000-0915FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 25.750 s
Processing PPM file: RM-356_52.0.101.502.02.rofs3.fpsx
[BB5,XSR 1.5] size: 1.12 MB
Erase size: 13 MB
CMT FLASH,MuxOneNAND area [09160000-09E5FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 1.140 s
Processing CNT file: RM-356_52.0.007_026_000_U01.uda.fpsx
[BB5,XSR 1.5] size: 7.09 MB
Erase size: 88.75 MB
CMT FLASH,MuxOneNAND area [09E60000-0F71FFFF]
Programming completed in 8.250 s
Total time for flashing process(boot+erase+write) was 2 min 35.781 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
| I flash it with same product code but set cannot boot,
when I press power button, it just vibrate only and not on,
any hardware or software solution??? |
