09-24-2012, 05:54 | #1 (permalink) |
Freak Poster Join Date: Jun 2011 Location: phillippines
Member: 1602100 Status: Offline Sonork: 100.1619004 Thanks Meter: 129 | nokia 5800d autorestart done by mxkey nokia logo then restarting logs.. Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085209E Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0000A49A Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Processing MCU file: RM-356_60.0.003_prd.core.C00 [BB5,XSR 1.5] size: 110.45 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 17B0001897950052B50736AFACC3FE6B2F5261A5 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CERT backup skipped. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 76A20187 [RAP Certificate 106 v1] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 2 min 19.375 s Processing PPM file: RM-356_60.0.003_prd.rofs2.V22 [BB5,XSR 1.5] size: 31.72 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 31.87 MB CMT FLASH,MuxOneNAND area [07180000-0915FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 42.359 s Processing CNT file: RM-356_60.0.001_026_000_U01.uda.fpsx [BB5,XSR 1.5] size: 7.09 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 88.75 MB CMT FLASH,MuxOneNAND area [09E60000-0F71FFFF] Flash programming ... Programming completed in 10.437 s Total time for flashing process(boot+erase+write) was 3 min 20.640 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia 5800 XpressMusic USB Phonet, PORT_ID: 37E83EC6 Verifying communication to device OK. Phone type: RM-356 (Nokia 5800 XpressMusic) SW version: V ICPR72_10w29_tube1 24-05-11 RM-356 (c) Nokia ApeCoreSw: V 60.0.003 Imei plain: 35201204228227-6 Product code: 0588613 Battery voltage: 3589 mV, current: 310 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352012042282276 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 4500000088401881 PROFILE_BITS: 8000000000000000 BLOCK1: 1=OPEN |
