04-06-2011, 07:52 | #3 (permalink) |
No Life Poster Join Date: Jan 2008 Location: karoondi khairpur pakistan
Member: 669947 Status: Offline Sonork: 100.1614053 Thanks Meter: 157 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011) ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0055189A:2984DA60 ASIC type: 2 UEM Imei: 35624100056521 Flash Imei: 35624100056521 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35624100056521_BA CK.rpl" Processing MCU file: rm30__04.900 [DCT4,DCT4 ALGORITHM] size: 8.31 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143 ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0055189A:3B8ADA60 Area [01000000-0101FFFF] erased in 1.218 s Area [01020000-0185FFFF] erased in 1 min 21.234 s Area [01E60000-01FDFFFF] erased in 14.672 s Flash programming ... Programming completed in 1 min 22.766 s File Processed in 3 min 9.906 s Processing CNT file: rm30__04.90.image_a [DCT4,DCT4 ALGORITHM] page size: 64 K size: 1.50 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143 ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0055189A:0BDFDA6A Area [01A60000-01E5FFFF] erased in 38.125 s Flash programming ... Programming completed in 15.109 s Content extract fail, continue anyway ... File Processed in 1 min 25.359 s Processing PPM file: rm30__04.90a [DCT4,DCT4 ALGORITHM] size: 1.50 MB Supported Ids: 1131, 1130, 2140, 2141, 2142, 2143 ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 0055189A:2984DA60 Area [01860000-01A5FFFF] erased in 19.531 s Flash programming ... Programming completed in 16.235 s File Processed in 47.796 s Total time for flashing process(boot+erase+write) was 5 min 23.109 s After Flash Processing ... Reseting Factory Values OK. Phone Type: RM-30 (Nokia 6020) SW Version: V 04.90 09-05-06 RM-30 (c) Nokia. Imei plain: 35624100056521-8 Imei OTP: 35624100056521 Product Code: 0520341 Cellular System: GSM ASIC ID: 0x2142, type: 2 Ppm Id: A Language Pack: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic Imei net: 35624100056521 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: AD89B3856D3A22AA PROFILE_BITS: A6C64C1910FDA3EF SIMLOCK_DATA corrupted! |
04-06-2011, 07:54 | #4 (permalink) |
Member: 669947 Status: Offline Sonork: 100.1614053 Thanks Meter: 157 | Imei net: 35624100056521 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: AD89B3856D3A22AA PROFILE_BITS: A6C64C1910FDA3EF SIMLOCK_DATA corrupted! Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35624100056521 Version: SIMLOCK SERVER VERSION 58 Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 1, size 11 bytes written. - Key: 2, size 86 bytes written. - Key: 4, size 114 bytes written. - Key: 5, size 2 bytes written. - Key: 6, size 86 bytes written. - Key: 8, size 114 bytes written. - Key: 11, size 8 bytes written. - Key: 12, size 2 bytes written. - Key: 13, size 86 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 86 bytes written. - Key: 18, size 86 bytes written. - Key: 20, size 86 bytes written. Section: 2 - Key: 0, size 336 bytes written. Section: 3 - Key: 0, size 3 bytes written. Section: 4 - Key: 0, size 1 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 44 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 12, size 51 bytes written. - Key: 13, size 1 bytes written. - Key: 16, size 4 bytes written. Section: 5 - Key: 0, size 78 bytes written. Section: 7 - Key: 0, size 4 bytes written. - Key: 1, size 40 bytes written. - Key: 2, size 2 bytes written. Section: 8 - Key: 0, size 12 bytes written. - Key: 1, size 12 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 8 bytes written. Section: 10 Warning: failed to write 10 - 0 (20 bytes) Warning: failed to write 10 - 1 (20 bytes) Warning: failed to write 10 - 2 (20 bytes) Warning: failed to write 10 - 3 (20 bytes) Warning: failed to write 10 - 4 (20 bytes) Warning: failed to write 10 - 5 (20 bytes) Warning: failed to write 10 - 6 (20 bytes) Warning: failed to write 10 - 7 (20 bytes) Warning: failed to write 10 - 8 (20 bytes) Warning: failed to write 10 - 9 (20 bytes) Warning: failed to write 10 - 10 (20 bytes) Warning: failed to write 10 - 11 (20 bytes) Warning: failed to write 10 - 12 (20 bytes) Warning: failed to write 10 - 13 (20 bytes) Warning: failed to write 10 - 14 (20 bytes) Warning: failed to write 10 - 15 (20 bytes) Warning: failed to write 10 - 16 (20 bytes) Warning: failed to write 10 - 17 (20 bytes) Warning: failed to write 10 - 18 (20 bytes) Warning: failed to write 10 - 19 (20 bytes) Warning: failed to write 10 - 20 (20 bytes) Warning: failed to write 10 - 21 (20 bytes) Warning: failed to write 10 - 22 (20 bytes) Warning: failed to write 10 - 23 (20 bytes) Warning: failed to write 10 - 24 (20 bytes) Warning: failed to write 10 - 25 (20 bytes) Warning: failed to write 10 - 26 (20 bytes) Warning: failed to write 10 - 27 (20 bytes) Warning: failed to write 10 - 28 (20 bytes) Warning: failed to write 10 - 29 (20 bytes) Warning: failed to write 10 - 30 (20 bytes) Warning: failed to write 10 - 31 (20 bytes) Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 1 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 2 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 16 bytes written. - Key: 19, size 2 bytes written. - Key: 20, size 2 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 2 bytes written. - Key: 44, size 2 bytes written. - Key: 45, size 2 bytes written. - Key: 46, size 2 bytes written. - Key: 47, size 2 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 2 bytes written. - Key: 51, size 2 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 2 bytes written. - Key: 54, size 2 bytes written. - Key: 55, size 2 bytes written. - Key: 56, size 2 bytes written. - Key: 57, size 2 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 2 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 1 bytes written. - Key: 62, size 4 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 4 bytes written. - Key: 66, size 16 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 2 bytes written. - Key: 69, size 21 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 13 - Key: 0, size 1 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 2 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 48 bytes written. - Key: 12, size 4 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 886 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 21, size 1 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 1 bytes written. - Key: 24, size 1 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 1 bytes written. - Key: 27, size 1 bytes written. - Key: 28, size 1 bytes written. - Key: 29, size 1 bytes written. - Key: 30, size 1 bytes written. - Key: 31, size 1 bytes written. - Key: 32, size 1 bytes written. - Key: 33, size 1 bytes written. - Key: 34, size 1 bytes written. - Key: 35, size 1 bytes written. - Key: 36, size 1 bytes written. - Key: 37, size 4 bytes written. - Key: 38, size 1 bytes written. - Key: 39, size 1 bytes written. - Key: 40, size 1 bytes written. - Key: 41, size 1 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 1 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 47, size 1 bytes written. - Key: 48, size 4 bytes written. - Key: 49, size 1 bytes written. - Key: 50, size 1 bytes written. - Key: 51, size 1 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 55, size 1 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 1 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 1 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 62, size 1 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 1 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 1 bytes written. - Key: 69, size 1 bytes written. - Key: 70, size 1 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 1 bytes written. - Key: 74, size 4 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 1 bytes written. - Key: 79, size 1 bytes written. - Key: 80, size 1 bytes written. - Key: 81, size 1 bytes written. - Key: 82, size 1 bytes written. Section: 33 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. Section: 35 - Key: 0, size 10 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 36 bytes written. - Key: 14, size 36 bytes written. - Key: 15, size 36 bytes written. - Key: 16, size 36 bytes written. - Key: 17, size 36 bytes written. - Key: 18, size 36 bytes written. - Key: 19, size 36 bytes written. - Key: 20, size 36 bytes written. - Key: 21, size 36 bytes written. - Key: 22, size 36 bytes written. - Key: 23, size 40 bytes written. - Key: 24, size 40 bytes written. - Key: 25, size 40 bytes written. - Key: 26, size 40 bytes written. - Key: 27, size 40 bytes written. - Key: 28, size 40 bytes written. - Key: 29, size 40 bytes written. - Key: 30, size 40 bytes written. Section: 46 - Key: 0, size 8 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 53 - Key: 1, size 56 bytes written. - Key: 2, size 48 bytes written. - Key: 3, size 48 bytes written. - Key: 4, size 48 bytes written. - Key: 5, size 48 bytes written. - Key: 6, size 48 bytes written. - Key: 8, size 48 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 55 - Key: 0, size 20 bytes written. Section: 56 - Key: 0, size 1 bytes written. Warning: failed to write 56 - 1 (1 bytes) Warning: failed to write 56 - 2 (4 bytes) Section: 58 - Key: 0, size 15 bytes written. Section: 59 - Key: 0, size 52 bytes written. - Key: 1, size 40 bytes written. - Key: 2, size 76 bytes written. - Key: 3, size 28 bytes written. - Key: 4, size 51 bytes written. - Key: 5, size 51 bytes written. - Key: 6, size 27 bytes written. - Key: 7, size 40 bytes written. - Key: 8, size 40 bytes written. - Key: 9, size 50 bytes written. - Key: 10, size 58 bytes written. - Key: 11, size 52 bytes written. - Key: 12, size 27 bytes written. - Key: 13, size 52 bytes written. Section: 60 - Key: 0, size 25 bytes written. - Key: 1, size 45 bytes written. Section: 61 - Key: 0, size 39 bytes written. - Key: 1, size 37 bytes written. - Key: 2, size 57 bytes written. - Key: 3, size 31 bytes written. - Key: 4, size 55 bytes written. Section: 65 - Key: 0, size 11 bytes written. - Key: 1, size 11 bytes written. - Key: 2, size 11 bytes written. - Key: 3, size 11 bytes written. - Key: 4, size 11 bytes written. Section: 66 - Key: 0, size 40 bytes written. - Key: 1, size 40 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 40 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 2 bytes written. - Key: 12, size 4 bytes written. - Key: 13, size 4 bytes written. - Key: 14, size 4 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 18, size 2 bytes written. - Key: 20, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 32, size 63 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 1 bytes written. - Key: 38, size 2 bytes written. - Key: 48, size 4 bytes written. - Key: 49, size 4 bytes written. - Key: 50, size 4 bytes written. - Key: 51, size 4 bytes written. - Key: 52, size 4 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 55, size 4 bytes written. - Key: 56, size 4 bytes written. - Key: 57, size 4 bytes written. - Key: 58, size 4 bytes written. - Key: 59, size 4 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 1800 bytes written. - Key: 69, size 60 bytes written. - Key: 70, size 4800 bytes written. - Key: 71, size 300 bytes written. - Key: 72, size 40 bytes written. - Key: 73, size 12 bytes written. - Key: 74, size 4 bytes written. Section: 67 - Key: 0, size 200 bytes written. Section: 76 - Key: 0, size 530 bytes written. Section: 83 - Key: 0, size 811 bytes written. - Key: 1, size 791 bytes written. - Key: 2, size 1054 bytes written. - Key: 3, size 774 bytes written. - Key: 4, size 576 bytes written. - Key: 5, size 850 bytes written. - Key: 6, size 940 bytes written. - Key: 7, size 910 bytes written. Section: 84 - Key: 0, size 3 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 89 bytes written. Section: 87 - Key: 0, size 4 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 91 - Key: 0, size 2048 bytes written. Section: 94 - Key: 0, size 40 bytes written. Section: 95 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 110 - Key: 0, size 6 bytes written. Section: 111 - Key: 0, size 200 bytes written. - Key: 1, size 20 bytes written. - Key: 2, size 20 bytes written. - Key: 126, size 20 bytes written. - Key: 127, size 20 bytes written. - Key: 150, size 8 bytes written. - Key: 151, size 4 bytes written. - Key: 152, size 40 bytes written. Section: 116 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 36 bytes written. - Key: 14, size 36 bytes written. - Key: 15, size 36 bytes written. - Key: 16, size 36 bytes written. - Key: 17, size 36 bytes written. - Key: 18, size 36 bytes written. - Key: 19, size 36 bytes written. - Key: 20, size 36 bytes written. - Key: 21, size 36 bytes written. - Key: 22, size 36 bytes written. - Key: 23, size 40 bytes written. - Key: 24, size 40 bytes written. - Key: 25, size 40 bytes written. - Key: 26, size 40 bytes written. - Key: 27, size 40 bytes written. - Key: 28, size 40 bytes written. - Key: 29, size 40 bytes written. - Key: 30, size 40 bytes written. - Key: 31, size 40 bytes written. - Key: 32, size 40 bytes written. Section: 117 - Key: 0, size 4 bytes written. - Key: 1, size 3 bytes written. - Key: 2, size 6 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 9 bytes written. - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 3 bytes written. Section: 118 - Key: 0, size 1 bytes written. - 120 skipped Section: 127 Warning: failed to write 127 - 1 (614 bytes) - Key: 2, size 614 bytes written. - Key: 3, size 614 bytes written. - Key: 4, size 614 bytes written. - Key: 5, size 614 bytes written. - Key: 6, size 614 bytes written. - Key: 7, size 614 bytes written. - Key: 8, size 614 bytes written. - Key: 9, size 614 bytes written. - Key: 10, size 614 bytes written. - Key: 11, size 614 bytes written. - Key: 12, size 614 bytes written. - Key: 13, size 614 bytes written. - Key: 14, size 614 bytes written. - Key: 15, size 614 bytes written. - Key: 16, size 614 bytes written. - Key: 17, size 614 bytes written. - Key: 18, size 614 bytes written. - Key: 19, size 614 bytes written. - Key: 20, size 614 bytes written. - Key: 21, size 614 bytes written. - Key: 22, size 614 bytes written. - Key: 23, size 614 bytes written. - Key: 24, size 614 bytes written. - Key: 25, size 614 bytes written. - Key: 26, size 614 bytes written. - Key: 27, size 614 bytes written. - Key: 28, size 614 bytes written. - Key: 29, size 614 bytes written. - Key: 30, size 614 bytes written. - Key: 31, size 614 bytes written. - Key: 32, size 614 bytes written. - Key: 33, size 614 bytes written. - Key: 34, size 614 bytes written. - Key: 35, size 614 bytes written. - Key: 36, size 614 bytes written. - Key: 37, size 614 bytes written. - Key: 38, size 614 bytes written. - Key: 39, size 614 bytes written. - Key: 40, size 614 bytes written. - Key: 41, size 614 bytes written. - Key: 42, size 614 bytes written. Section: 150 - Key: 0, size 30 bytes written. - Key: 1, size 82 bytes written. - Key: 2, size 82 bytes written. - Key: 3, size 82 bytes written. - Key: 4, size 82 bytes written. - Key: 5, size 82 bytes written. - Key: 6, size 82 bytes written. - Key: 7, size 82 bytes written. - Key: 8, size 82 bytes written. - Key: 9, size 82 bytes written. - Key: 10, size 82 bytes written. - Key: 11, size 82 bytes written. - Key: 12, size 82 bytes written. - Key: 13, size 82 bytes written. - Key: 14, size 82 bytes written. - Key: 15, size 82 bytes written. - Key: 16, size 82 bytes written. - Key: 17, size 82 bytes written. - Key: 18, size 82 bytes written. - Key: 19, size 82 bytes written. - Key: 20, size 82 bytes written. - Key: 21, size 82 bytes written. - Key: 22, size 82 bytes written. - Key: 23, size 82 bytes written. - Key: 24, size 82 bytes written. Section: 157 - Key: 1, size 260 bytes written. - Key: 2, size 252 bytes written. - Key: 3, size 232 bytes written. - Key: 4, size 264 bytes written. - Key: 5, size 260 bytes written. - Key: 6, size 244 bytes written. - Key: 7, size 244 bytes written. - Key: 8, size 256 bytes written. - Key: 9, size 232 bytes written. - Key: 10, size 232 bytes written. - Key: 11, size 256 bytes written. - Key: 12, size 232 bytes written. - Key: 13, size 232 bytes written. - Key: 14, size 232 bytes written. - Key: 15, size 232 bytes written. - Key: 16, size 248 bytes written. - Key: 17, size 232 bytes written. - Key: 18, size 232 bytes written. - Key: 19, size 244 bytes written. - Key: 20, size 232 bytes written. - Key: 21, size 232 bytes written. - Key: 22, size 248 bytes written. - Key: 23, size 248 bytes written. - Key: 24, size 232 bytes written. - Key: 25, size 252 bytes written. - Key: 26, size 248 bytes written. - Key: 27, size 232 bytes written. - Key: 28, size 256 bytes written. - Key: 29, size 248 bytes written. - Key: 30, size 232 bytes written. - Key: 31, size 252 bytes written. - Key: 32, size 248 bytes written. - Key: 33, size 232 bytes written. - Key: 34, size 256 bytes written. - Key: 35, size 248 bytes written. - Key: 36, size 232 bytes written. - Key: 37, size 248 bytes written. - Key: 38, size 232 bytes written. - Key: 39, size 232 bytes written. - Key: 40, size 232 bytes written. - Key: 41, size 232 bytes written. - Key: 42, size 232 bytes written. - Key: 43, size 232 bytes written. - Key: 44, size 232 bytes written. - Key: 45, size 232 bytes written. - Key: 46, size 232 bytes written. - Key: 47, size 232 bytes written. - Key: 48, size 232 bytes written. - Key: 49, size 232 bytes written. - Key: 50, size 232 bytes written. - Key: 51, size 232 bytes written. Completed in 1 min 26.984 s |
04-06-2011, 08:00 | #5 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 38
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | bro full erase phone and flash again after flash write rpl via mx-key thrn unlock ... and post result |
