Old 05-24-2011, 06:36   #1 (permalink)
Member: 1480973
Thanks Meter: 25
nokia 6070 RM-166 phone restricted
nokia 6070 RM-166 phone restricted plz help
mxkey log
MXKEY Serial: [FT SCR2000 0] - xxxxxxxx
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0
Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
ASIC ID: 0x3160 [UPP_8M ver: 6.0]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0020 8804 [ST 58LR128U,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690
Performing Flash Authentication ...OK
UEM ID: 00C44397:2984DA60
ASIC type: 2
UEM Imei: 00701159186
Flash Imei: 00701159186
MasterCode: 5170474000
RPL saved to "C:\mobileEx\3.5\data\backup\00701159186_BACK. rpl"
Phone Type: RM-166 (Nokia 6070)
SW Version: V 04.20 07-12-06 RM-166 (c) Nokia.
Imei plain: ??????????????-?
Imei OTP: 00701159186
Product Code: 0533305
Cellular System: GSM
ASIC ID: 0x3160, type: 2
Ppm Id: BD
Language Pack:
English,German,Slovak,Slovene,Serbian,Hungarian,Cz ech,Croatian
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!
Old 05-24-2011, 06:43   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,377
Check IMEI with your Back Panel if same with = 00701159186
Then write RPL & if need Unlock it
The Following User Says Thank You to srinibas For This Useful Post:
Old 05-24-2011, 06:44   #3 (permalink)
Member: 59185
Sonork: 100.1593175
Thanks Meter: 4,911
repair imei by rpl .
then repair simlock .
also from info there is a chance of corrupted uem .
The Following User Says Thank You to lalitjsraks For This Useful Post:
Old 05-24-2011, 07:04   #4 (permalink)
Member: 1480973
Thanks Meter: 25
mxkey log
ASIC type: 2
Ppm Id: BD
Language Pack:
Easy Imei restore backup
Easy Imei restore for DCT4 phones started.
ASIC type: 2
Investigating flash imei ...
Calculating Imei restore ...
Programming FLASH Imei ...
FLASH programmed successfully.
Imei restore succesfull !
if you were restoring from imei patched phone, you should reflash the firmware to remove SW patch.
Imei OTP: 00709547794
Ppm Id: BD
Language Pack:
mxkey SERVER
Reading ASK DATA ...
ASIC type: 2
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.7
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\00701159186.R PL"
Ppm Id: BD
Language Pack:
Old 05-24-2011, 07:06   #5 (permalink)
Member: 59185
Sonork: 100.1593175
Thanks Meter: 4,911
read carefully .
http://forum.gsmhosting.com/vbb/7355503-post3.html
probably a bad or corrupted uem .
Old 05-24-2011, 07:18   #6 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
Thanks Meter: 348
hardware problem,change ume bro.
The Following User Says Thank You to net.tarik For This Useful Post:
Page generated in 0.21713 seconds with 9 queries
