08-09-2011, 09:54 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: India Age: 37
Member: 145082 Status: Offline Thanks Meter: 798 | Nokia 6120c unable to repair simlock (ANSWERED) i got rpl backup what can be done here o repair the simlocks... plzzz help me up here mx team SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! MXKEY Serial: [FT SCR2000 0] - C0804635 Using device: HTI BOX, FW ver: 00.17 Driver: usbuhci:usbhub:usbccgp:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17841(12-07-2011), Library ver: 1.0.0.11875(12-07-2011) Product: Using cached productData. PUBLIC ID: 16200016928E00529712CE235D443FFA8853EA18 PRIVATE ID: D8BE019F7C7E817B0CCF2D240444AA4FD3826D83 E-FUSE: E6E6914D SEC ROM CRC: 3E691FF8 ERROR: read packet failed or calculation failed (status: 0) Reading Simlock info ... |
08-09-2011, 09:55 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Post Info/Bus Check LOG here, You will clear why not Unlocking ??? 1st know the Simlock Type B4 attempting Unlock |
08-09-2011, 10:16 | #3 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | Phone Type: RM-243 (Nokia 6120) SW Version: V 07.20 05-10-09 RM-243 (c) Nokia Imei plain: 35198304223888-3 Product Code: 0547930 Battery voltage: 4778 mV, current: 150 mA ApeCoreSw: 07.20 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
08-09-2011, 10:17 | #4 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 16200016928E00529712CE235D443FFA8853EA18 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.16.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.16.0 revision: 2.0 size: 0x878E8 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 0FE1BA92D924A658E4800780FA6F4868100AC947 Original Imei: 35198304223888 Original Product code: 0550022 Bluetooth ID: 5C57C8BEC05F SIMLOCK PA identifier: [0] PA_SL2 Phone Type: RM-243 (Nokia 6120) SW Version: V 07.20 05-10-09 RM-243 (c) Nokia Imei plain: 35198304223888-3 Product Code: 0547930 Battery voltage: 4778 mV, current: 133 mA Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
08-09-2011, 10:22 | #5 (permalink) | |
Freak Poster Join Date: Feb 2011 Location: IN-GSM-WORLD
Member: 1516406 Status: Offline Thanks Meter: 33 | Quote:
Do You Use HTI Flasher Interface ??? | |
08-09-2011, 12:24 | #7 (permalink) |
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | It can B easily done , Bcoz it is SIMLOCK PA identifier: [0] PA_SL2 contact me on messenger if you need any further help |
08-10-2011, 08:22 | #11 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | Phone Type: RM-243 (Nokia 6120) SW Version: V 07.02 18-05-09 RM-243 (c) Nokia Imei plain: 35198304223888-3 Battery voltage: 4793 mV, current: 164 mA Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! here's the log for the phone can someone help me out to sort this phone... |
08-10-2011, 08:25 | #12 (permalink) |
Member: 145082 Status: Offline Thanks Meter: 798 | when i try to repair it with me mxkey its giving me this error : SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! MXKEY Serial: [FT SCR2000 0] - C0804635 Using device: HTI BOX, FW ver: 00.17 Driver: usbuhci:usbhub:usbccgp:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17841(12-07-2011), Library ver: 1.0.0.11875(12-07-2011) Product: SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.10.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 PUBLIC ID: 16200016928E00529712CE235D443FFA8853EA18 PRIVATE ID: D8BE019F7C7E817B0CCF2D240444AA4FD3826D83 E-FUSE: E6E6914D SEC ROM CRC: 3E691FF8 ERROR: read packet failed or calculation failed (status: 0) Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
10-04-2011, 13:02 | #15 (permalink) |
Freak Poster Join Date: Dec 2007 Location: bangladesh
Member: 648277 Status: Offline Thanks Meter: 161 | MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C0857B18 Using device: HTI BOX, FW ver: 00.17 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 07400103B8950052C3FDAE8D689C2217B13927FF ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.24.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.24.0 revision: 2.0 size: 0x87D1A Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 0FE1BA92D924A658E4800780FA6F4868100AC947 Original Imei: 35198304836202 Original Product code: 0567078 Bluetooth ID: D875335108A9 SIMLOCK PA identifier: [0] PA_SL2 Phone type: RM-243 (Nokia 6120) SW version: V 07.20 05-10-09 RM-243 (c) Nokia Imei plain: 35198304836202-6 Product code: 0567078 Battery voltage: 4708 mV, current: 142 mA ApeCoreSw: 07.20 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
