Old 10-05-2012, 04:29   #1 (permalink)
Member: 806190
Nokia 6275i not flashing
Log:
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C0*****
Using device: HTI, FW ver: 00.50, SN: 01*****
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
ASIC ID: 0x2051 [TikuEdge ver: 2.0]
SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398
Supported Ids: 1051, 1052, 2051
FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M)
FlashID2: 0000 0001 [unused/removed]
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5
Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8
Performing Flash Authentication ...OK
UEM ID: 002D8A6A:3B8ADA60
ASIC type: 6
UEM Imei: 0111*****
Flash Imei: 0111*****
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\01111011109_BACK. rpl"
Processing MCU file: BL190V0500_rus_ruim.nep
[TIKU BT2,TIKU ALGORITHM] size: 12.28 MB
Area [00000000-0001FFFF] erased in 0.875 s
Area [00020000-00DFFFFF] erased in 1 min 34.515 s
Flash programming ...
Programming completed in 1 min 6.344 s
File processed in 2 min 51.984 s
Processing CNT file: BL190_05w21_58_02_01_REL04_rus_ruim.image_fa
[TIKU BT2,TIKU MON CSM] size: 7.83 MB
Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660
Mass Memory Storage Device detected.
Configuring MM bus ...
Formating partition ...OK
Opening MM device ...
Erasing disks ...OK
Превышен таймаут семафора
Error while programming [2E] at 0x00000020, Result: 0000
flashing terminated !
I can`t flash... Any help?
Old 10-05-2012, 04:47   #2 (permalink)
him82's Avatar
Member: 646646
Sonork: 100.1664464
Thanks Meter: 240
i think hardware problem ram and flash light hit or clean pcb any try to sucseess ....
chk voltage of vflash
this is cdma phone dear
Old 10-05-2012, 19:05   #3 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
untick safe and fast flash then try.
BR.
Arsalan gsm2000.
Page generated in 0.13002 seconds with 8 queries
