08-15-2012, 11:24 | #1 (permalink) |
No Life Poster Join Date: Jun 2009
Member: 1051835 Status: Offline Sonork: 100.1594332 Thanks Meter: 514 | Nokia 6300 Contact Service, But On Flasher Normal Mode Ok On. Hello, i have nokia 6300 when i power on with battery set show on startup Contact Service, but when i'm boot in flasher in normal mode set fine working. here is log. any solution of this problem. MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0xxxxx Using device: USB ROM and HTI, FW ver: 00.50, SN: 010xxxxx Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Processing MCU file: rm217__07.30.mcusw [BB5,BB5 ALGORITHM] size: 14.50 MB Supported Ids: 0103192101001101, 010C192101001101 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAP3G ver: PA 1.x] CMT EM0 ID: 00000232 CMT EM1 ID: 00000353 CMT PUBLIC ID: 16A0020406427B56F33F28BAF2DAE40053609B12 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID: 191EC665DFAAF68F Flashing CMT Update Server Data, ULO: 0x38C0 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x3CA00 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x4A9C0 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 1F37807E Verifying communication to device OK. Erase size: 16.37 MB CMT FLASH,NOR area [00000000-000006BF] erased in 0.360 s CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.015 s CMT FLASH,NOR area [00020000-0007FFFF] erased in 1.078 s CMT FLASH,NOR area [00080000-000DFFFF] erased in 0.063 s CMT FLASH,NOR area [00100000-001FFFFF] erased in 0.171 s CMT FLASH,NOR area [00200000-0031FFFF] erased in 3.266 s CMT FLASH,NOR area [00320000-0105FFFF] erased in 37.719 s CMT FLASH,NOR area [01060000-01067FFF] erased in 0.360 s CMT FLASH,NOR area [01068000-0107FFFF] erased in 0.015 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 7F7E6491 [RAP Certificate 52 v1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT PMM_CONF block sent CMT SBIF_CONF block sent Programming completed in 1 min 39.500 s Processing PPM file: rm217__07.30.ppm_c [BB5,BB5 ALGORITHM] size: 4.51 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 5.50 MB CMT FLASH,NOR area [01080000-015FFFFF] erased in 13.391 s Flash programming ... Programming completed in 31.282 s Processing CNT file: rm217__07.30.image_c_tr_white [BB5,BB5 ALGORITHM] page size: 64 K size: 3.19 MB Supported Ids: 0103192101001101, 010C192101001101 Erase size: 9.87 MB CMT FLASH,NOR area [01600000-01FDFFFF] erased in 10.859 s Flash programming ... Programming completed in 21.438 s Total time for flashing process(boot+erase+write) was 4 min 21.250 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 6300 USB Phonet, PORT_ID: 20C3E7F8 Verifying communication to device OK. Phone type: RM-217 (Nokia 6300) SW version: V 07.30 07-05-09 RM-217 (c) Nokia. Imei plain: 35571402914813-4 Product code: 0515890 Battery voltage: 3815 mV, current: 192 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 355714029148134 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... Ok |
The Following User Says Thank You to ~The JoKeR~ For This Useful Post: |
08-15-2012, 11:39 | #3 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Inside GBKey
Member: 1676092 Status: Offline Sonork: 100.1609037 Thanks Meter: 123 | broi hope this cause is hardware Problem like RETU ic run self test check which is failed |
The Following User Says Thank You to GBKeyHelp For This Useful Post: |
08-15-2012, 12:41 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Check in Hardware, specially BSI Line or from Selftest: 'EAR_DATA_LOOP' failed means, Change Retu IC will solve it. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
08-15-2012, 16:11 | #6 (permalink) |
No Life Poster Join Date: Apr 2011 Location: kerala
Member: 1550704 Status: Offline Sonork: 100.1644808 Thanks Meter: 248 | try to right the pm file........ RM-217_2.pm - 4shared.com - online file sharing and storage - download |
08-15-2012, 16:26 | #7 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Are you sure it's PM Prob ? Bro. It's Hardware, can see Logs for Software & it's OK BR, ZUBER | |
08-16-2012, 03:39 | #11 (permalink) |
Freak Poster Join Date: Feb 2009
Member: 961313 Status: Offline Sonork: 100.1625300 Thanks Meter: 35 | bro check and disable bluetooth ic -1/ remove "fusible n 3" -2/ check the phone. 3/ if phon start normaly then change bluetooth ic [IMG]http://1.bp.********.com/_vRVHdFZowYo/SvpvAouq7_I/AAAAAAAAADA/yHxGOlQKHHM/s1600-h/6300short1.JPG[/IMG] http://1.bp.********.com/_vRVHdFZowY...6300short1.JPG if not check or rehot network ic !! ....etc it's a hard problem Last edited by Dr.Dekra; 08-16-2012 at 03:45. |
