Old 10-10-2010, 07:12   #1 (permalink)
shabir97's Avatar
Member: 1277468
Sonork: 100.1603661
Thanks Meter: 701
Arrow nokia 6300 contact service ..plz help me
i have a nokia 6300rm-217
set is dead before flashing i flash to latest version (7.21)set is on but after startup is showing contect service.
write good pm file .
i try to this mathod but still same
(1)first make backup
(2) read pm to 0 to 500
(3) erase it with bb5 erase file
(4) full flash the mobile with new version
here is a flash logo
Version from phone: 07.21
Version from file: 07.21
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35828803040031_BA CK.rpl).
Processing file: rm217__07.21.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 14.50 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 26200113BD458C56C879E9AE4AC3AC92FA2F27A0
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT NOR area [00000000-000006BF] erased in 0.391 s
CMT NOR area [000006C0-0001FFFF] erased in 0.157 s
CMT NOR area [00020000-0007FFFF] erased in 1.093 s
CMT NOR area [00080000-000DFFFF] erased in 0.187 s
CMT NOR area [00100000-001FFFFF] erased in 0.328 s
CMT NOR area [00200000-0031FFFF] erased in 3.110 s
CMT NOR area [00320000-0105FFFF] erased in 34.625 s
CMT NOR area [01060000-01067FFF] erased in 0.437 s
CMT NOR area [01068000-0107FFFF] erased in 0.156 s
Flash programming ...
CMT PAPUBKEYS: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9 (RAP Certificate 52 v1) written.
Programming completed in 8 min 23.234 s
Processing file: rm217__07.21.ppm_mea4 as PPM
[BB5,BB5 ALGORITHM] size: 3.79 MB
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 5.50 MB
CMT NOR area [01080000-015FFFFF] erased in 10.546 s
Programming completed in 2 min 18.000 s
file rm217__07.21_sd_mea_512.fpsimage is empty, skipped.
Processing file: rm217__07.21.image_mea4 as CNT
[BB5,BB5 ALGORITHM] page size: 64 K size: 3.32 MB
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 9.87 MB
CMT NOR area [01600000-01FDFFFF] erased in 25.593 s
Converting UCP blocks to 128 K.
Programming completed in 1 min 51.828 s
Flashing completed in 14 min 12.187 s
After Flash Processing ...
Phone Type: RM-217 (Nokia 6300)
SW Version: V 07.21 05-11-08 RM-217 (c) Nokia.
Imei plain: 35828803040031-0
Product Code: 0546632
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 358288030400310
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Total time to process is 14 min 32.172 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 3.203 s
The Following User Says Thank You to shabir97 For This Useful Post:
Old 10-10-2010, 07:15   #2 (permalink)
AsiaGSM™'s Avatar
Member: 599306
Sonork: 100.1578386
Thanks Meter: 5,136
now repaid SD and write PM 120 and 308, 309 from server
it will be fine
Old 10-10-2010, 07:17   #3 (permalink)
reyfer24's Avatar
Member: 1044690
Sonork: 100.1617308
Thanks Meter: 56
Amigo repara la superdongle y luego repara el security test failed. En esta misma sección de la mxkey encontraras muchos tutoriales de como reparar el Contact Service, solo es cuestión de buscar... Éxitos!!!
Friend superdongle repairs and then repair the failed test security. In this section of the mxkey find many tutorials on how to repair Contact Service is only a matter of looking ... Success!
http://forum.gsmhosting.com/vbb/f550...orters-933420/
Old 10-10-2010, 07:17   #4 (permalink)
shinod's Avatar
Member: 55363
Thanks Meter: 146
SIMLOCK_TEST passed
try to repair sd and write pm file.........
Old 10-10-2010, 07:20   #5 (permalink)
nk_sho's Avatar
Member: 1361078
Thanks Meter: 49
Old 10-10-2010, 08:02   #6 (permalink)
Master Software's Avatar
Member: 1149013
Thanks Meter: 247
repair sd and write pm 1 to 309
Old 10-10-2010, 08:08   #7 (permalink)
shabir97's Avatar
Member: 1277468
Sonork: 100.1603661
Thanks Meter: 701
my problum well be solved with repair sd
Page generated in 0.22831 seconds with 9 queries
