02-10-2010, 13:21 | #1 (permalink) |
Insane Poster Join Date: Oct 2007
Member: 609820 Status: Offline Thanks Meter: 6 | 1661 unlock problem pls 1661 mx key unlock problem error 0x14 Imei net: 3582xxxxxxxxxxx Version: SIMLOCK SERVER Provider: Vodafone D2 (DCT4), Country: Germany Counter: 0/3, 0/10 CONFIG_DATA: 2620200000000000 PROFILE_BITS: 8000000000030002 BLOCK 1: 1.LOCKED (MCC+MNC): 26202F BLOCK 2: 1.LOCKED (MCC+MNC): F401F411F421F431F441F451F461F471F481F491 BLOCK 3: 1.LOCKED (MCC+MNC): F402F412F422F432F442F452F462F472F482F492F502F512F5 22F532F542F562F572F582F592F602F612F622F632F642F652 F662F672F682F692F702F712F722F732F742F752F762F772F7 82F792F802F812F822F832F842F852F862F872F882F892 BLOCK 4: 1.LOCKED (MCC+MNC): F153F163F173F183F193F303F313F323F333F343F353F363F3 73F383F393F503F513F523F533F543F563F573F583F593F603 F613F623F633F643F653F663F673F683F693F703F713F723F7 33F743F753F763F773F783F793F803F813F823F833F843F853 F863F873F883F893 BLOCK 5: 1.LOCKED (MCC+MNC): F104F114F124F134F144F214F224F234F244F254F264F274F2 84F294F304F314F324F334F344F354F364F374F384F394F404 F414F424F434F444F454F464F474F484F494F504F514F524F5 34F544F564F574F584F594F604F614F624F634F644F704F714 F724F734F744F754F764F774F784F794F804F814F824F834F8 44F954F964F974F984F994 BLOCK 6: 1.LOCKED (MCC+MNC): F105F115F125F135F145F205F215F225F235F245F305F315F3 25F335F345F355F365F375F385F395F405F415F425F435F445 F455F465F475F485F495F505F515F525F535F545F565F575F5 85F595F605F615F625F635F645F655F665F675F685F695F705 F715F725F735F745F755F765F775F785F795 BLOCK 7: 1.LOCKED (MCC+MNC): F906F916F926F936F946F956F966F976F986F996 PhoneType:RH-122 SwVersion: V 03.70 14-04-09 RH-122 (c) Nokia MCU file: rh122_003.700 Trying to find patch position ...OK, case id: 3 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0035A486:2984DA60 Area [01000000-0101FFFF] erased in 0.735 s Area [01160000-0117FFFF] erased in 0.719 s Programming ... Programming completed. Updating SIMLOCK ...Error 0x14 ASIC ID: 0x2293 [UPPCosto ver: 2.0] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2254 [Samsung ] page size: 64 K type: NOR area: 01000000-01FFFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0035A486:2984DA60 Area [01000000-0101FFFF] erased in 0.719 s Area [01160000-0117FFFF] erased in 0.687 s Programming ... Programming completed. |
02-10-2010, 13:38 | #3 (permalink) |
Member: 609820 Status: Offline Thanks Meter: 6 | |
MXkey nokia 1661 unlock problem | merkeza | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-20-2010 20:07 |
1661 unlock problem | billa2008 | Nokia Hardware & Hardware Repair | 3 | 10-02-2009 15:47 |
6310i ver 5.22 unlock problem ... pls help ... | alianu | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 06-17-2003 20:55 |
GD 55 Unlock Problem - PLS Help | Synchro | Panasonic | 0 | 05-14-2003 07:25 |
Geo@i mt345 unlock problems....pls help | PTR999 | Mitsubishi | 0 | 10-14-2002 09:56 |
