02-10-2010, 15:44 | #3 (permalink) |
Insane Poster Join Date: Aug 2007
Member: 572236 Status: Offline Thanks Meter: 10 | 2630 imei change Hi there I done a RM298 2630 version 57.20 today for the first time and was easy. Flashed and unlocked the phone first then go to the service tab / IMEI & security / imei changes. Hit scan then replace the imei with the one you want and then hit change imei (i also checked skip unlock) easy. PhoneType:RM-298 SwVersion: V 57.20 09-02-09 RM-298 (c) Nokia MCU file: rm298__57.20.mcusw Trying to find patch position ...OK New Imei: 356097008111326 ASIC ID: 0x3168 [UPP_8M ver: 6.4] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 2310 0340 C605 E401 20A2 0000 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00563760:3B8ADA60 Area [01000000-0101FFFF] erased in 0.375 s Area [016C0000-016DFFFF] erased in 0.375 s Area [013E0000-013FFFFF] erased in 0.375 s Area [01480000-0149FFFF] erased in 0.359 s Area [01C20000-01C3FFFF] erased in 0.375 s Programming ... Programming completed. SpUnlock skipped. Completed in 55.953 s Phone Type: RM-298 (Nokia 2630) SW Version: V 57.20 09-02-09 RM-298 (c) Nokia Imei plain: 35609700811132-6 Imei OTP: 35606503824372 Product Code: 0585849 Cellular System: GSM ASIC ID: 0x3168, type: 11 Ppm Id: EJ Language Pack: English,Russian,Ukrainian Imei net: 35609700811132 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
02-10-2010, 16:09 | #4 (permalink) |
No Life Poster Join Date: Jul 2005 Location: turkey, izmir
Member: 163458 Status: Offline Sonork: 100.1606694 Thanks Meter: 503 | video here thanx button ) http://forum.gsmhosting.com/vbb/showthread.php?t=919108 |
02-10-2010, 16:21 | #5 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1170910 Status: Offline Thanks Meter: 76 | PhoneType:RM-298 SwVersion: V 06.82 26-09-08 RM-298 (c) Nokia MCU file: rm298__06.82.mcusw Trying to find patch position ...OK New Imei: 353121020653314 ASIC ID: 0x3162 [UPP_8M ver: 6.2] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 0020 881C [ST M58LR256JU,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000 Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0001F8CF:3B8ADA60 Area [01000000-0101FFFF] erased in 0.610 s Area [016C0000-016DFFFF] erased in 0.610 s Area [013E0000-013FFFFF] erased in 0.610 s Area [01480000-0149FFFF] erased in 0.625 s Area [01C20000-01C3FFFF] erased in 0.625 s Programming ... Programming completed. Updating SIMLOCK ...OK Completed in 50.875 s Phone Type: RM-298 (Nokia 2630) SW Version: V 06.82 26-09-08 RM-298 (c) Nokia Imei plain: 35312102065331-4 Imei OTP: 00000000000000 Cellular System: GSM ASIC ID: 0x3162, type: 11 Ppm Id: MR Language Pack: - not available. Imei net: 35312102065331 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000001000B BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
2630 imei change but no signal | vicky784 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-27-2010 09:42 |
2630 imei chang succesful but no service | khanmobiles0003 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 03-24-2010 20:40 |
NOKIA 2630 imei change???? | Ramzan khan | Universalbox | 5 | 01-30-2010 12:55 |
Nokia 2630 after change imei set into contect service | Sahil2007 | Universalbox | 13 | 02-09-2009 21:31 |
