02-21-2010, 11:49 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1042497 Status: Offline Thanks Meter: 40 | nokia 6301 RM-323 unlock error Version: SIMLOCK SERVER Provider: T-Mobile, Country: U.S.A. Counter: 0/3, 0/10 CONFIG_DATA: 3102000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 310160, DATA=310160 BLOCK 2: 1=LOCKED (MCC+MNC): 310200, DATA=310200 BLOCK 3: 1=LOCKED (MCC+MNC): 310210, DATA=310210 BLOCK 4: 1=LOCKED (MCC+MNC): 310220, DATA=310220 BLOCK 5: 1=LOCKED (MCC+MNC): 310230, DATA=310230 BLOCK 6: 1=LOCKED (MCC+MNC): 310240, DATA=310240 BLOCK 7: 1=LOCKED (MCC+MNC): 310250, DATA=310250 BLOCK 8: 1=LOCKED (MCC+MNC): 310260, DATA=310260 BLOCK 9: 1=LOCKED (MCC+MNC): 310270, DATA=310270 BLOCK 10: 1=LOCKED (MCC+MNC): 310310, DATA=310310 BLOCK 11: 1=LOCKED (MCC+MNC): 310580, DATA=310580 BLOCK 12: 1=LOCKED (MCC+MNC): 310660, DATA=310660 BLOCK 13: 1=LOCKED (MCC+MNC): 310800, DATA=310800 BLOCK 14: 1=LOCKED (MCC+MNC): 310490, DATA=310490 Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 05.93 16-04-08 RM-323 (c) Nokia SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending SecondaryBoot [rap3gv3_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x3948 bytes) ...OK ERROR=ROM not supported! help ? ? |
02-21-2010, 11:52 | #2 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | 1st. update your module Quote:
br, | |
02-21-2010, 11:58 | #3 (permalink) |
Freak Poster Join Date: Jan 2007 Location: in gsmhosting Age: 36
Member: 426321 Status: Offline Sonork: 100.1602578 Thanks Meter: 91 | wath version are u used..??use latest version 2.01 sl2 and tré again if you have 6301b u need to converter too 6301 with 6301bandlock.rpl use search boton good luck |
The Following User Says Thank You to abd_aziz2006 For This Useful Post: |
02-21-2010, 11:58 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Pakistan Age: 36
Member: 300354 Status: Offline Sonork: 100.1577485 Thanks Meter: 760 | Select PA_SL2 and Do As MobileEx-Team Told You... |
The Following User Says Thank You to .::Skylinks::. For This Useful Post: |
02-21-2010, 12:03 | #5 (permalink) |
Member: 1042497 Status: Offline Thanks Meter: 40 | look ..... mt box Phone is in: Local mode Model: RM-323 ( RM-323) V 05.93/16-04-08/RM-323 (c) Nokia Production serial number KIR396417 Product code 0557512 Module code 0203491 Basic production code 0549193 Flash code Order number Long production SN 0 MCU SW V 05.93/16-04-08/RM-323/(c) Nokia HW 1502 PCI RFIC 17211721 DSP ICPR71_08w03_3_1 LCD SEIKO PPM V 05.93/16-04-08/RM-323/(c) Nokia /NTM BT MCM 2222-143 Retu 32 Tahvo 53 Content Pack Content: tmobusa v1/07-May-08/RM-323/(c) Nokia. IMEI: 353112021801184 WARNING: VPP pin is not connected, disabling VPP. Phone is in: Local mode Imei: 353112021801184 353112021801184 Backup SIMLOCK: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\353112021801184.pm Section 78: , 00[1D0], 01[50], 02[14], 03[70] Section 134: , 00[1], 01[2000], 03[1], 04[1], 05[A], 06[1], 07[1], 08[1], 09[28] Reading phone PM 308:1... Booting Phone... rap3gv3_2nd.fg Test call... cpsr - 0x0000001F p15_1 - 0x0005307F p15_2 - 0x0005117F p15_3 - 0x0005317F esn_init ret - 0x00000001, <tmp_buff2> - 0x00000001 esn_read ret - 0x00000001, <tmp_buff2> - 0x00000001 BB5+ ptr - 0x0004B440 !!! FAILED !!! THIS IS AN SL2 Phone, Invoking SL2 unlock procedure 353112021801184 V 05.93/16-04-08/RM-323 (c) Nokia IMEI: 353112021801184 Operator: 8000000000000000 Profile bits: 3102000000000000 Closed on Mcc Mnc: 310160 Closed on Mcc Mnc: 310200 Closed on Mcc Mnc: 310210 Closed on Mcc Mnc: 310220 Closed on Mcc Mnc: 310230 Closed on Mcc Mnc: 310240 Closed on Mcc Mnc: 310250 Closed on Mcc Mnc: 310260 Closed on Mcc Mnc: 310270 Closed on Mcc Mnc: 310310 Closed on Mcc Mnc: 310580 Closed on Mcc Mnc: 310660 Closed on Mcc Mnc: 310800 Closed on Mcc Mnc: 310490 Backup simlock Backup SIMLOCK: C:\Program Files\GriffinTeam\MT-Box\bb5bckup\353112021801184_n.pm 353112021801184 Booting Phone... Searching loader rap3gv3_2nd.fg Operation SUCCESSFULL C:\Program Files\GriffinTeam\MT-Box\bb5bckup\last.pm Delay 5 seconds ... Phone is in: Local mode Delay 1 sec... Imei: 353112021801184 Send Eeprom 308:1 RestartPhone V 05.93/16-04-08/RM-323 (c) Nokia IMEI: 353112021801184 Operator: 2440700000000000 Operator Name: AT&T;U.S.A. (3650) Profile bits: 0000000000000000 Sim Status: Not locked #pw+876015627403665+7# Sending code to phone 353112021801184 SUCCESSFULL, ALREADY UNLOCKED Finished in 31s Finished in 45s no serves ???? |
02-21-2010, 12:08 | #6 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
because u not used simlock RPL to unlock this model next time use simlock RPL for such models thanx | |
02-21-2010, 12:29 | #8 (permalink) | |
No Life Poster Join Date: May 2007 Age: 42
Member: 501674 Status: Offline Sonork: THEIF OF HEART Thanks Meter: 883 | Quote:
Nokia 6301b rm 323 unlock done!!!! | blood rAyne | Nokia Base Band 5 ( BB-5 ) | 0 | 04-25-2009 12:21 |
nokia 6301 RM-323 | dindou78 | BB5KING | 0 | 12-30-2008 17:20 |
Nokia 6288 RM-78 Unlock Error on BB5king v1.06 | rajinder1978 | BB5KING for (BB5BOX) | 6 | 11-21-2008 14:28 |
Nokia 6301 RM-322 unlock ! | glontz | BB5BOX | 1 | 02-20-2008 13:07 |
