Old 04-23-2011, 04:03   #1 (permalink)
ask4moon's Avatar
Member: 531289
Sonork: 100.1603200
Thanks Meter: 292
nokia 6303 flashing Error (ANSWERED)
please support team help me how can i repair my phone.
log:
Version from phone: 10.12
Version from file: 10.10
Using device: POTATO BOX, FW ver: 01.B1
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011)
Reading phone`s ID ...
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
productData saved.
Restarting phone ...
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1E900016E2867D56FF4BDD0FBD5A65F8B3D8D69B
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2
TransmissionMode: DDR&TX2
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Flash Imei: 353199037****
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_353199037****_BAC K.rpl"
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Processing MCU file: rm443__10.10.mcusw
[BB5,BB5 ALGORITHM] size: 24.67 MB
Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000
Storing certificate [NPC, R&D, CCC, HWC] ...OK
Erase size: 28.25 MB
CMT NOR area [00000000-0001FFFF]
CMT NOR area [00040000-0005FFFF]
CMT NOR area [00060000-0007FFFF]
CMT NOR area [00080000-0015FFFF]
CMT NOR area [00160000-0023FFFF]
CMT NOR area [01740000-0191FFFF]
CMT NOR area [00240000-0173FFFF]
CMT NOR area [022E0000-0261FFFF]
erased in 2 min 24.172 sFlash programming ...
CMT PAPUBKEYS: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 (RAP Certificate 140 v.1) written.
Programming completed in 4 min 17.297 s
Processing PPM file: rm443__10.10.ppm_mb
[BB5,BB5 ALGORITHM] size: 5.74 MB
Erase size: 9.75 MB
CMT NOR area [01920000-022DFFFF]
erased in 37.078 sFlash programming ...
Programming completed in 1 min 23.094 s
Processing MMC file: rm443__10.10_sd_MENA_EU_Cities_1024.fpsimage
[BB5,BB5 ALGORITHM] version: 0.0.0 size: 220.04 MB
erase skipped (no erase descriptor).
Erase skipped.
Error while programming [00] at 0x00020000, Result: 0000
Quick reply will be appreciated
Old 04-23-2011, 04:26   #2 (permalink)
Member: 1559197
Sonork: 100.1604096
Thanks Meter: 425
bro i think ur set have faulty flash chip...........try again with dead usb flashing
The Following User Says Thank You to solution4all For This Useful Post:
Old 04-23-2011, 08:00   #3 (permalink)
ask4moon's Avatar
Member: 531289
Sonork: 100.1603200
Thanks Meter: 292
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 27D832D0
CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
CMT EM0 ID: 00000295
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 1E900016E2867D56FF4BDD0FBD5A65F8B3D8D69B
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x69180 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x77780 bytes
Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 38E172E8
Verifying communication to device OK.
CMT NOR area [00000000-0001FFFF] erased in 0.782 s
CMT NOR area [00040000-0005FFFF] erased in 0.656 s
CMT NOR area [00060000-0007FFFF] erased in 0.750 s
CMT NOR area [00080000-0015FFFF] erased in 5.219 s
CMT NOR area [00160000-0023FFFF] erased in 4.954 s
CMT NOR area [01740000-0191FFFF] erased in 11.406 s
CMT NOR area [00240000-0173FFFF] erased in 2 min 10.578 s
CMT NOR area [022E0000-0261FFFF] erased in 19.829 s
Programming completed in 1 min 38.484 s
Erase size: 9.75 MB
CMT NOR area [01920000-022DFFFF] erased in 59.344 s
Programming completed in 22.468 s
No Erase header defined, erase will be skipped
Erase skipped.
Programming completed in 8 min 31.984 s
Processing CNT file: rm443__10.10.image_mb_pk_steel
[BB5,BB5 ALGORITHM] page size: 128 K size: 9.76 MB
Erase skipped.
Error while programming [00] at 0x029C0000, Result: 0000
support teem where are u ?
help me...
Old 04-23-2011, 09:48   #4 (permalink)
wanshuai163's Avatar
Member: 1513547
Sonork: 琥珀帅
Thanks Meter: 18
hi bro ... you can use hwk to flash it ...... or use mx test self ........
choice right flash file ... your phone will be ok ...
at last ...... you can use phonix flash it ..
Old 04-23-2011, 12:50   #5 (permalink)
MANOLE's Avatar
Member: 780644
Sonork: 100.88888
Thanks Meter: 131,943
http://forum.gsmhosting.com/vbb/f613...ection-967354/
Closed.
The Following User Says Thank You to MANOLE For This Useful Post:
Page generated in 0.17969 seconds with 9 queries
