02-07-2013, 10:21 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: AT YOUR EYES
Member: 747386 Status: Offline Thanks Meter: 30 | nokia 6303 rm 443 contect sevice nokia 6303 rm 443 contect service here is log Phone type: RM-443 (Nokia 6303 classic) SW version: V 10.12 08-04-10 RM-443 (c) Nokia Imei plain: 35319903939756-0 Product code: 0577406 Battery voltage: 4851 mV, current: 52 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353199039397560 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
02-08-2013, 08:37 | #3 (permalink) | |
Member: 747386 Status: Offline Thanks Meter: 30 | Quote:
br zuber now phone is sim not valid hereis log Phone type: RM-133 (Nokia N73) SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia. ApeCoreSw: V 4.0850.43.0.1 Imei plain: 35640601980133-0 Battery voltage: 4337 mV, current: 196 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356406019801330 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN | |
02-08-2013, 08:45 | #4 (permalink) | |
No Life Poster Join Date: May 2010 Location: Samsung Mobile Philippines
Member: 1300241 Status: Offline Sonork: 100.1626973 Thanks Meter: 356 | Quote:
repair sd & super sd auth it solved Last edited by Asia_Phone; 02-08-2013 at 08:51. | |
02-08-2013, 08:50 | #5 (permalink) | ||
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Am facing Diabetic problem, so not seen properly your problem without Specs, Your problem is Security Failed & solution is below. Use this Method, Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-443.PM file, Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result. Quote:
Use this Method for your 2nd Phone N73, Go to Service Tab > Click Super SD Auth, Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-133.PM file, Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result. BR, ZUBER | ||
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
02-08-2013, 10:15 | #6 (permalink) | |
br zuber bhai allah app ko sehat de meri dua hei an other nokia 6303 rm 443 here is log Phone type: RM-443 (Nokia 6303 classic) SW version: V 09.10 25-08-09 RM-443 (c) Nokia Imei plain: 35319903715215-7 Product code: 0569445 Battery voltage: 4324 mV, current: 62 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! | |
02-08-2013, 11:19 | #7 (permalink) | |
Bro. It's SL3 Phone, Need Backup RPL or Simlock for it, If no Backup, then only Factory RPL is the option. BR, ZUBER | |
