04-03-2011, 02:24 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Northern Ireland
Member: 1514899 Status: Offline Thanks Meter: 49 | Nokia 6500 Classic Flashing Problem (ANSWERED) Can you tell me why to flash Nokia 6500 classic is so hard?? Tried via Fbus and ereased all data but when coming to upload then error comes, why?? Why this bug or Bootoader is still not fixed? What I have now is dead Nokia and no battery so I can not flash it with USB. How Can I solve this? I Unlocked this phone but when tried to de-brand problem occured!! |
04-03-2011, 03:41 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, there is no problem on handling this phone. if can do unlock by using simlock rpl method, you should be able to flash it too. what you mean with bootloader 'bug' exactly? can you post the logs? on most case, TX2 not responding caused by bad cable. see your cable quality, not the cable BRAND. and about USB flashing for this kind phone, which usb line is together with charger plug, do a little trick: on turned of phone with fully charged battery, press flash, insert usb cable after. that's it. ps. do not use usb hub. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
04-03-2011, 09:47 | #3 (permalink) | |
Member: 1514899 Status: Offline Thanks Meter: 49 | Quote:
But the problem is that I don't have the battery and hence I can't flash via USB. | |
04-03-2011, 10:51 | #4 (permalink) |
Member: 1514899 Status: Offline Thanks Meter: 49 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9274(01-03-2011), 1.0.0.15868(10-03-2011) Processing MCU file: rm265__09.48.mcusw [BB5,BB5 ALGORITHM] size: 18.13 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1780000957B05550DA3C1A778E3259A8DF460B26 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: D0D8948DEF333BF18141EF4C3D0FB1B002EB5D88 TransmissionMode: DDR&TX2 Erase size: 21.12 MB CMT NOR area [00000000-0001FFFF] erased in 0.390 s CMT NOR area [00040000-000BFFFF] erased in 1.516 s CMT NOR area [000C0000-0013FFFF] erased in 0.187 s CMT NOR area [013C0000-0153FFFF] erased in 3.140 s CMT NOR area [00140000-013BFFFF] erased in 4.328 s Flash programming ... CMT PAPUBKEYS: D0D8948DEF333BF18141EF4C3D0FB1B002EB5D88 (RAP Certificate 87 v1) written. Error while programming [00] at 0x000A0400, Result: 0000 Please try to use newer flashloader. RX Buffer: B372 |
04-03-2011, 23:56 | #6 (permalink) |
Member: 1514899 Status: Offline Thanks Meter: 49 | Phone Type: RM-265 (Nokia 6500c) SW Version: V 09.48 26-01-09 RM-265 (c) Nokia Imei plain: 12345610654321-? Product Code: 0555828 Language Pack: - not available. Imei plain is invalid !!! SIMLOCK_DATA corrupted! |
04-04-2011, 04:57 | #8 (permalink) | |
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
im sure you made backup before. BR | |
04-05-2011, 19:15 | #9 (permalink) |
Member: 1514899 Status: Offline Thanks Meter: 49 | Hi Yes, I made a backup but when press restore imei I get this: Easy Imei restore for BB5 phones started. CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1780000957B05550DA3C1A778E3259A8DF460B26 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F Looking for backup for this phone ... No backup found! and when try to write rpl I get this: missing NPC data in the RPL file, skipped. Updating SIMLOCK...error 0x1 Phone Type: RM-265 (Nokia 6500c) SW Version: V 09.48 26-01-09 RM-265 (c) Nokia Imei plain: 12345610654321-? Product Code: 0555828 Language Pack: - not available. Imei plain is invalid !!! SIMLOCK_DATA corrupted! Please help me to solve this problem |
04-05-2011, 19:42 | #12 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | you can contact Fast Unlocking. please upload here all your RPL file on your backup folder for those IMEI (see cover). C:\mobileEx\3.4\data\backup ..learning by doing.. this is should not be happened if you made a correct backup before. BR |
04-05-2011, 19:45 | #13 (permalink) | |
But thanks for helping me Best Regards | |
