06-09-2011, 17:18 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Bosnia
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | nokia 6500c dead fix bug (ANSWERED) Using device: HTI BOX, FW ver: 00.08 Driver: FTDIBUS, ver: 2.8.14.0 , NTMP ver: 2.8.12.0 Module ver: 1.0.0.17309(31-05-2011), Library ver: 1.0.0.10695(31-05-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1DA00107F14D025499F2197ADC0C43C88936B9A6 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 10.6.0 revision: 0.0 size: 0x3C40 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 10.28.0 revision: 0.0 size: 0x23220 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: D0D8948DEF333BF18141EF4C3D0FB1B002EB5D88 TransmissionMode: DDR&TX2 Processing MCU file: rm265__06.61.mcusw [BB5,BB5 ALGORITHM] size: 18.11 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 21.12 MB CMT NOR area [00000000-0001FFFF] CMT NOR area [00040000-000BFFFF] CMT NOR area [000C0000-0013FFFF] CMT NOR area [013C0000-0153FFFF] CMT NOR area [00140000-013BFFFF] erased in 57.703 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D0D8948DEF333BF18141EF4C3D0FB1B002EB5D88 (RAP Certificate 87 v1) sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 52.016 s Processing PPM file: rm265__09.48.ppm_d [BB5,BB5 ALGORITHM] size: 5.59 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 6.50 MB CMT NOR area [01540000-01BBFFFF] erased in 15.766 s Flash programming ... Programming completed in 27.375 s Processing CNT file: rm265__09.48_ISM_007.image_d_silver [BB5,XSR 1.5] page size: 128 K size: 10.84 MB Supported Ids: 0103192101003000, 010C192101003000 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 35.87 MB CMT NOR area [01EC0000-03F9FFFF] CMT NOR area [01BC0000-01EBFFFF] erased in 1 min 54.125 s Flash programming ... Programming completed in 47.031 s Total time for flashing process(boot+erase+write) was 6 min 24.844 s Phone Type: RM-265 (Nokia 6500c) SW Version: V 06.61 26-03-08 RM-265 (c) Nokia Imei plain: 35866701325748-4 Product Code: 0558041 Battery voltage: 4821 mV, current: 71 mA Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358667013257484 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000006 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN when turn on only the nokia logo appears and automatically shuts down .. I tried the same usb no result.... same version i flashed with ub phone alive.. please fix bug... |
The Following User Says Thank You to sajohaker For This Useful Post: |
06-10-2011, 04:39 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, negative as bugs. i personally tested with other rap3gv3 phones. same hash no problem. with UB you flashed higher version, that's why it's good. RM-265 v06.61 is old enough BR |
06-10-2011, 09:50 | #3 (permalink) | |
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | Quote:
rm265__09.48.mcusw rm265__09.48.ppm_d rm265__09.48_ISM_007.image_d_silver but mx flashed v06.61.mcusw I do not know why otherwise the only fbus MX-BOX is going to end. on the same cable tried to hwk ATF ub no result.flashing error.. My opinion is that the more time the bug will be removed with very good tools for fbus flashing | |
06-10-2011, 15:52 | #4 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, your market configuration is messed up, no matter what file you load into it, it will use the file setting from market .ini. on good working files config should be like this, right after you select such market: Code: Phone Type: RM-265 TimeStamp: 2008-11-26T15:51:06Z SW Version: 09.45 Variant Version: 006 ProductProfile: RM265_0560650_09.45_006.spr Simlock: 0560650_simlock.bin Language Pack: English,Chinese Simpl,Chinese Trad,Bahasa Indonesia please delete your rm-265 folder, reinstall phone data package, or create new one by scan and image dl. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
