03-19-2010, 01:24 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Irvinestown
Member: 719399 Status: Offline Thanks Meter: 228 | Nokia 6610i Unlock Tell me wich other cable can be used to unlock Nokia 6610i. I know 6610, 6610I, 7210, 7250, but 7210 that I have is 2-3 pinout Can anyone help. |
03-19-2010, 01:59 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, it's rm-37, right? all types that you mentioned are all compatible. it can be used without any problem. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
03-19-2010, 02:19 | #4 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | it should be work. i use the same cable as you are. check for phone pinout, suspect: back cover + cable battery pack no fitted correctly. try with buscheck instead of scan. BR |
03-19-2010, 02:34 | #5 (permalink) | |
Member: 719399 Status: Offline Thanks Meter: 228 | Quote:
I'll check BUS CHECK but I doubt | |
Unlock code for nokia 6610i | dany82 | Phone Unlocking Codes & Maps | 2 | 08-25-2005 18:39 |
unlock code for nokia 6610i wanted | belly515 | Phone Unlocking Codes & Maps | 2 | 03-24-2005 21:37 |
