11-24-2012, 14:03 | #1 (permalink) | |
Freak Poster Join Date: Oct 2010 Location: jamnagar(gujarat)india Age: 33
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | nokia 6700 classic flash ok but no power on ?????????? also hardware is very cleaned , set not opened still with company sealed pack please help me Quote:
The Following User Says Thank You to HBHAVNA For This Useful Post: |
11-24-2012, 19:19 | #3 (permalink) |
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | phone product code is 0571137 and set is dead before flashing i first download latest firmware then flash it, but still same |
11-24-2012, 21:01 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, If you have all necessary Backup, Then you can try to Erase Phone & Flash it, If appears in Test Mode, then Write Backup, If not solve, then have to check in Hardware, Possibility of Boot & Power related Error, Have to check N3301 & Gazoo ICs. BR, ZUBER |
11-25-2012, 04:50 | #5 (permalink) | |
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | [QUOTE=.::ZUBER::.;8963002]Hi, If you have all necessary Backup, Then you can try to Erase Phone & Flash it, If appears in Test Mode, then Write Backup, If not solve, then have to check in Hardware, Possibility of Boot & Power related Error, Have to check N3301 & Gazoo ICs. sorry sir i dont have full rpl backup because its cant boot in test or local mode i have only this temp crt.rpl file created when i flash the set check here Quote:
if it working after i erase the set ! then i try but i dont think its hardware because set hardware is very fresh sir. even i first time open the set | |
11-25-2012, 07:50 | #7 (permalink) | |
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | Quote:
mr.Zuber please help me bro. | |
11-25-2012, 08:05 | #8 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Post your Backup RPL to check Simlock, Or you can also check it with Notepad, whether Simlock Data there in Backup RPL, Then do Erase from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/, Post reply. BR, ZUBER |
11-25-2012, 08:27 | #9 (permalink) |
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | but backuped rpl is only 4 kb sizes that means not full back up ! right ? and its a crt,rpl that means only temp based rpl for only imei restore what u think? also tell how to check rpl using notepad , please explain it sir, thanks for guide me any way. |
11-25-2012, 08:38 | #10 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Click OK will see RPL data in Text Format on Notepad. P.S. But if Software Read & Backup RPL of Dead Phone, means possibility of Hardware Damage, Boot, Current Sense & Power Control Section. BR, ZUBER | |
11-25-2012, 11:53 | #11 (permalink) | ||
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | RPL back up details please check it, as fast as possible ? Quote:
here is the rpl log in notepad Quote:
also here is attached RPL file | ||
11-25-2012, 14:03 | #12 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, Simlock Data not in Backup, 1- Try Reflow PCB & Flash it again, 2- Phone came Dead, so try Erase in this situation, Nothing to loose. BR, ZUBER |
