10-04-2010, 07:13 | #1 (permalink) | |
Freak Poster Join Date: Jan 2008
Member: 681216 Status: Offline Sonork: 100.1584492 Thanks Meter: 177 | Nokia 6700c can"t work SD-Repire (answered) SW Version: V 13.10 16-06-10 RM-470 (c) Nokia Imei plain: 35318103850442-0 Product Code: 0570913 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353181038504420 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000002 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Quote:
The Following 4 Users Say Thank You to rezactgbd For This Useful Post: |
10-04-2010, 07:21 | #2 (permalink) | |
No Life Poster Join Date: Sep 2008 Location: Living with mobile phones
Member: 856803 Status: Offline Sonork: 100.1592550 Thanks Meter: 151 | Quote:
Post bugs logs here,so team will help u | |
The Following User Says Thank You to ..::MOBILES::.. For This Useful Post: |
10-04-2010, 08:09 | #3 (permalink) | |
Member: 681216 Status: Offline Sonork: 100.1584492 Thanks Meter: 177 | see i m already post with log super dongle key invalid Quote:
11-14-2010, 06:18 | #4 (permalink) |
Junior Member Join Date: Feb 2008
Member: 698589 Status: Offline Thanks Meter: 5 | Block 1: 1=open 2=open 3=open 4=open 5=open, data=ffffff block 2: 1=open 2=open 3=open 4=open 5=open, data=ffffff block 3: 1=open 2=open 3=open 4=open 5=open, data=ffffff block 4: 1=open 2=open 3=open 4=open 5=open, data=ffffff block 5: 1=open 2=open 3=open 4=open 5=open, data=ffffff block 6: 1=open 2=open 3=open 4=open 5=open, data=ffffff block 7: 1=open 2=open 3=open 4=open 5=open, data=ffffff |
11-15-2010, 14:18 | #8 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 906499 Status: Offline Sonork: sen-i Thanks Meter: 47 | CMT Data : SYSTEM ASIC ID: 00000003000002260001xxxxxxxxxxx [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 23A0000A095F0344B7xxxxxxxxxxxx ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DECxxxxxxxx ROM ID: 3E273BF6xxxxx SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Programming Status: [NAND ERROR: 00060E4E5043000000000000000000Certificate programmed successfully ! CMT Data : SYSTEM ASIC ID: 0000000300000226000xxxxxxxxxxxxx [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 23A0000A095xxxxxxxxxxxxxx ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BExxxxxxxxxxxxxxxxxxx ROM ID: 3E2xxxxxxxxxxxx SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 FlashID0: 00EC 0040 - 0080 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: MuxOneNAND,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Begin Certificate Request ... [InternalErrorFault] CERT [] data not available for this phone (case id=0xCE01) cannot write rpl to this phone too , flash ok via fbus , but no lokal mode , cannot write faktory rpl |
