08-27-2011, 06:55 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: india Age: 43
Member: 397892 Status: Offline Sonork: 100.1609899 Thanks Meter: 190 | nokia 6700c rm-470 not flash(ANSWERED) bus logs : > Code: MXKEY Serial: [FT SCR2000 0] - C0821173 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Connection status: UHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 07D00017A18C03448819A9F5193B152401F85579 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 eBB5ProtocolType: OLD Storage0: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit No RAP Flash Chip Detected Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 Error sending flashloader ! Code: MXKEY Serial: [FT SCR2000 0] - C0821173 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Connection status: UHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 07D00017A18C03448819A9F5193B152401F85579 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 eBB5ProtocolType: OLD Storage0: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit No RAP Flash Chip Detected Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Processing MCU file: rm470__13.21.mcusw [BB5,XSR 1.6] size: 25.21 MB Supported Ids: 6003192102021104, 600C192102021104, 6003192102011104, 600C192102011104, 0400000200000000 Storing certificate [NPC, CCC, HWC, R&D] ...Error Erase size: 43.81 MB CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-0009FFFF] CMT FLASH,MuxOneNAND area [000A0000-0041FFFF] CMT FLASH,MuxOneNAND area [00420000-0069FFFF] CMT FLASH,MuxOneNAND area [006A0000-01F1FFFF] CMT FLASH,MuxOneNAND area [02900000-02FBFFFF] CMT FLASH,MuxOneNAND area [0F2C0000-0F8BFFFF] CMT FLASH,MuxOneNAND area [00000000-0001FFFF] Formating partition ... Error 0000000000:00 Error Sync! Error 0000000000:00 Error Sync! Total time for flashing process(boot+erase+write) was 21.235 s also usb flash logs : > Code: MXKEY Serial: [FT SCR2000 0] - C0821173 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing MCU file: rm470__13.21.mcusw [BB5,XSR 1.6] size: 25.21 MB Supported Ids: 6003192102021104, 600C192102021104, 6003192102011104, 600C192102011104, 0400000200000000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 20D20379 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] CMT EM0 ID: 00000C34 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 07D00017A18C03448819A9F5193B152401F85579 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID: 3E273BF637BE26FA Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0098 0040 - 0000 0031 [Toshiba NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 20D20379 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35379004200508_CERT.rpl" CMT PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 43.81 MB CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-0009FFFF] CMT FLASH,MuxOneNAND area [000A0000-0041FFFF] CMT FLASH,MuxOneNAND area [00420000-0069FFFF] CMT FLASH,MuxOneNAND area [006A0000-01F1FFFF] CMT FLASH,MuxOneNAND area [02900000-02FBFFFF] CMT FLASH,MuxOneNAND area [0F2C0000-0F8BFFFF] CMT FLASH,MuxOneNAND area [00000000-0001FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: CABA40E4 [RAP Certificate 145 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT LDSP block sent CMT MCUSW block sent CMT ISA+DYNSW block sent Programming completed in 5.484 s Processing PPM file: rm470__13.21.ppm_ctm [BB5,XSR 1.6] size: 6.45 MB Supported Ids: 6003192102021104, 600C192102021104, 6003192102011104, 600C192102011104, 0400030000000002, 000000A000000028 Erase size: 9.87 MB CMT FLASH,MuxOneNAND area [01F20000-028FFFFF] Flash programming ... Programming completed in 1.438 s Processing CNT file: rm470__13.21_009.image_c_tmo_de_v4_86583 [BB5,XSR 1.6] size: 28.19 MB Supported Ids: 6003192102021104, 600C192102021104, 6003192102011104, 600C192102011104, 0400000200000000 Erase size: 195.06 MB CMT FLASH,MuxOneNAND area [02FC0000-0F2BFFFF] Formating partition ... Flash programming ... Programming completed in 4.828 s Total time for flashing process(boot+erase+write) was 1 min 0.625 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 20D20379 Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 20D20379 Open device failed: FFFFFFFF (4) The system cannot open the file Warning: Phone did not reboot to normal mode. plz help where is problem. thanxx |
