Member: 1488285
Thanks Meter: 28 | nokia 6730c vibrate only need help i have nokia 6730c vibrate only i need your help,,
action taken ;
flashing with mxbox n lock
heres a logs: Quote:
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0854BC4
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000A33D
Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.70
Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011)
Processing MCU file: rm566_023.010_prd.core.fpsx
[BB5,XSR 1.6] size: 88.26 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2B7241F1
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00000C34
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 25200201045D03441F57EF5C644056B537598C29
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
CMT ROM ID: 3E273BF637BE26FA
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35421203155828_CE RT.rpl).
CMT PAPUBKEYS HASH: 397DCE210733C335E84BAD369EC893FCA06D1BC3
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 181.06 MB
CMT FLASH,MuxOneNAND area [00020000-0003FFFF]
CMT FLASH,MuxOneNAND area [00060000-004DFFFF]
CMT FLASH,MuxOneNAND area [008E0000-0B93FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 397DCE21 [RAP Certificate 210 v1] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 1 min 46.594 s
Processing PPM file: rm566_023.010_C01.01_BLACK_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 8.20 MB
Erase size: 25 MB
CMT FLASH,MuxOneNAND area [0A040000-0B93FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 9.875 s
Processing CNT file: rm566_023.010_U000.000_prd.uda.fpsx
[BB5,XSR 1.6] size: 520.27 KB
Erase size: 61 MB
CMT FLASH,MuxOneNAND area [0B940000-0F63FFFF]
Programming completed in 1.032 s
Total time for flashing process(boot+erase+write) was 2 min 15.250 s
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode. |
thanks in advance.... |
