01-20-2012, 15:59 | #1 (permalink) |
No Life Poster Join Date: Jun 2007 Location: INDIA
Member: 530721 Status: Offline Thanks Meter: 157 | nokia 7210 simlock invalid Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35693003619400-7 Product code: 0514950 Battery voltage: 4871 mV, current: 62 mA Language Pack: - not available. SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! Failed to read SP data I think this hardware problem Failed to read SP data MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C0809343 Using device: HTI, FW ver: 00.50, SN: 00003BFB Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData. PUBLIC ID: 14800107EA118C56CA780C4294AA06450E735E59 PRIVATE ID: DF41B3657E806C7C918A0ED98347A51D3123537E Updating SIMLOCK ...error 0x14 Reading Simlock info ... Failed to read SP data if any one have tested solution pleas help me |
01-20-2012, 17:12 | #2 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Bosnia
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | Complete repair damaged simlock and superdongle by mxkey: 1. Backup RAP NPC Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL 2. FULL ERASE Flash > Advance : untick safe ERASE > Erase Flash 3. Flash MCU,PPM,CNT 4. Restore IMEI Service > Imei & Security > Imei Rebuild > Restore Imei 5. Repair SPLock Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock 6. Repair SD Service > Imei & Security > Imei Rebuild > Repair SD 7. Super SD Auth Service > PM > Super SD Auth 8. When super SD auth is done, write PM imediately. |
The Following User Says Thank You to sajohaker For This Useful Post: |
05-03-2012, 14:42 | #3 (permalink) |
Junior Member Join Date: Jan 2011 Location: Mumbai, Maharashtra, India.
Member: 1483851 Status: Offline Thanks Meter: 1 | i done all process but still same problem!!!!!! here is log Original Imei: 359310028***** Original Product code: 0566928 Bluetooth ID: 00247D0C2D86 SIMLOCK PA identifier: [0] PA_SL2 Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 3593100283****-* Product code: 0572571 Battery voltage: 4471 mV, current: 0 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SECURITY_TEST failed! Failed to read SP data |
05-03-2012, 19:46 | #4 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
br, | |
05-03-2012, 19:50 | #5 (permalink) |
Registered User Join Date: Sep 2005 Location: (earth°) Age: 46
Member: 181110 Status: Offline Sonork: 1001648353 Thanks Meter: 180 | i always flow this method and work in 95% times !! just try ...nothing to loose Procedure Step by step: 1-Backup Rpl full 2- reset NPC 3- write full modified pm 4- restore imei 5- Repair SD 6- Super SD auth 7- write pm 1 and 309 field only 8- Default all setting http://www.mediafire.com/bb5pm-by-delower#myfiles |
05-03-2012, 20:04 | #6 (permalink) | |
br, | |
