Old 06-05-2010, 09:29   #1 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Red face Nokia 7210 Supernova contrack service
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35931002133941-1
Product Code: 0566806
ApeVariant: I
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Failed to read SP data
Old 06-05-2010, 09:31   #2 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
it's only SECURITY_TEST failed!
first try in Super SD Auth and write pm in 1 & 309...............
Old 06-05-2010, 09:38   #3 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Bro super sd auth not working so now what ?????
Old 06-05-2010, 09:41   #4 (permalink)
amer_a_82's Avatar
Member: 610529
Sonork: 100.1612153
Thanks Meter: 18
sir u have cyclone box ?
Old 06-05-2010, 09:42   #5 (permalink)
amer_a_82's Avatar
Member: 610529
Sonork: 100.1612153
Thanks Meter: 18
if u have it
1- SX4
2- direct unlock
3-write pm
and ur problem solved enshlllah i try it
Old 06-05-2010, 10:29   #6 (permalink)
.::VENUGOPAL::.'s Avatar
Member: 1230663
Sonork: 100.1593487
Thanks Meter: 174
tick on load rfbb server press pmm auth & write pm
Old 06-05-2010, 12:23   #7 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
I all redy trying to do but not solve same condition,
Here is full log detail
Scan log
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 359310021339411
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Buc che log
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1D60020627055950C7E47EFFB125FED840E57A18
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
Original Imei: 35931002133941
Original Product code: 0566837
Bluetooth ID: 0024039D150D
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
BB5 certificat validation log
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Reading RAP NPC (0x168 bytes)
Original Product Code: 0566837
Reading RAP VARIANT (0x0 bytes)
Reading RAP CCC (0x160 bytes)
Product Code: 0566807
Product Code missmatch !
Reading RAP HWC (0xD4 bytes)
Super sd auth log
Product: V 07.23 17-07-09 RM-436 (c) Nokia
Using cached productData[1D60020627055950C7E47EFFB125FED840E57A18] ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Repait sd log
Calculating SUPERDONGLE using security server ...
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0
[CR2]BB5 remaining credit: 37
Completed in 12.328 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_359310021339411_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
Repair splock log
Calculating SIMLOCK using security server ...
[CR2]BB5 remaining credit: 36
Completed in 16.031 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_359310021339411_SIM.RPL"
Updating SIMLOCK...OK
Reading Simlock info ...
Counter: 0/3, 0/10
Old 06-05-2010, 12:58   #8 (permalink)
arvinddald's Avatar
Member: 582669
Sonork: 100.1592908
Thanks Meter: 69
bro u shld edit ur rpl... upload ur rpl here i wil do it for u...
Old 06-05-2010, 14:43   #9 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Here it is
4shared.com - online file sharing and storage - download BB5_35931002133941_BACK.rar
Old 06-05-2010, 14:51   #10 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
backup rpl
rest npc
go to pm click erase pm
writ rpl then click recover cert
simlock> click splock info then tick make simlock rpl then click update simlock
repair sd
go to pm >tick load rfbb from server then click SUPER SD AUTH and writ pm
fullfactory&format
Old 06-05-2010, 14:54   #11 (permalink)
FaHaD_DePaR's Avatar
Member: 1257171
Thanks Meter: 86
ApeVariant: I
Language Pack:
- not available.
SIMLOCK_TEST passed
repair sd
and after
write full pm
Old 06-05-2010, 19:59   #12 (permalink)
arvinddald's Avatar
Member: 582669
Sonork: 100.1592908
Thanks Meter: 69
bro chk dis.. 4shared.com - online file sharing and storage - download BB5_35931002133941edit_BACK.rar
aft not sloved with dis aslo contact me in yahoo....
Old 06-05-2010, 20:47   #13 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
Wink
Originally Posted by alasmmar View Post
backup rpl
rest npc
repair sd
fullfactory&format
here what can i do master help me check
Phone Type: RM-379 (Nokia 7310 Supernova)
SW Version: V 08.20 12-06-08 RM-379 (c) Nokia
Imei plain: 35415102252438-6
Product Code: 0568491
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
"C:\Archivos de programa\Nokia\Phoenix\Products\RM-379" folder created.
SIMLOCK_DATA corrupted!
Old 06-05-2010, 21:03   #14 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
Language Pack:
- not available.
SIMLOCK invalid!
go to MXKEY>SERVES>IMEI&SECURTY>simlock> click splock info then tick make simlock rpl then click update simlock
repair sd
fullfactory
Old 06-05-2010, 21:29   #15 (permalink)
wilmer's Avatar
Member: 392589
Sonork: 1597152
Thanks Meter: 50
dont have pm for this model simlock ok tanks
where i can find pm tanks
Page generated in 0.25950 seconds with 10 queries
