Old 10-18-2012, 18:56   #1 (permalink)
Member: 382783
Thanks Meter: 118
Nokia 7210c contact service !!!!!!
Hi ebry body
i flashed nokia 7210c gaves problem just shows Nokia & white screen
i erased the phone & i reflashed it again
but when i powered the phone & i pressed accept gaves contact service
this is log
SLPA ver[1]: PA_SL (15 digit NCK)
Camera config: NIMMIIIIRRFF094B2F01, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!
Old 10-18-2012, 19:42   #2 (permalink)
Member: 382783
Thanks Meter: 118
OK i repaired some errors but remais one
this is log
SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK)
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 355743023407626
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
Old 10-18-2012, 19:49   #3 (permalink)
.::GEANECIV::.'s Avatar
Member: 853097
Sonork: 100.1622287
Thanks Meter: 131
this is log
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Click Super SD Auth, write pm 1 & 309 only.
Old 10-18-2012, 20:03   #4 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Bro.
Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-436.PM file,
Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result.
Later Check Camera & it's Connector contacts or Change Camera.
BR,
ZUBER
Old 10-18-2012, 20:24   #5 (permalink)
Member: 382783
Thanks Meter: 118
Originally Posted by .::ZUBER::. View Post
Bro.
BR,
ZUBER
Thanks Bro i followed thesee steps but also the problem still
i clicked repair SD it's OK Done
when i clicked write gaves problem:
writing:failed to write (for all sections)
Old 10-18-2012, 20:38   #6 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,262
Problem in Hardware,
Clean PCB for Waterlogs,
Reflow Avilma & Combo ICs for Physical Damage,
Must solve it,
BR,
ZUBER
Old 10-18-2012, 20:38   #7 (permalink)
Member: 853097
Sonork: 100.1622287
Thanks Meter: 131
Hi....
Old 10-18-2012, 20:44   #8 (permalink)
Member: 853097
Sonork: 100.1622287
Thanks Meter: 131
No hardware problem, security failed just write pm 1,309 with super sd auth.
if still same. write 7210c_without_NPC_DATA__made_by_MxKey.rpl
Old 10-18-2012, 21:28   #9 (permalink)
Member: 382783
Thanks Meter: 118
Thanks for your helps Bros But the problem still
SIMLOCK_TEST passed
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
Page generated in 0.25622 seconds with 7 queries
