Old 08-03-2010, 10:37   #1 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
nokia 7210c contact servis problem
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35931002280022-1
Product Code: 0566807
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!
need help
Old 08-03-2010, 10:49   #2 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Hello,
Go to Service -> imei security-> simlock-> select make simlock rpl then hit update splock
The Following User Says Thank You to KK Mobile For This Useful Post:
Old 08-03-2010, 10:54   #3 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
bro when i try to repair simlock / update mx-key show this msg Updating SIMLOCK...error 0x1
Old 08-03-2010, 11:07   #4 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
need help.............................
Old 08-03-2010, 11:10   #5 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
tick make simlock Rpl and hit update
Old 08-03-2010, 11:17   #6 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
no bro problem same
log
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Product: V 07.23 17-07-09 RM-436 (c) Nokia
Using cached productData[02E0000F970459501619D8A5399B79C40D7B834F] ...
Calculating SIMLOCK using security server ...
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1
Completed in 2.921 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_359310022800221_SIM.RPL"
Reading Simlock info ...
Old 08-03-2010, 12:05   #7 (permalink)
Ramzan's Avatar
Member: 86597
Sonork: 100.1602630
Thanks Meter: 1,131
U need to make Bkup RPL and erease the Phone then Flash with latest Flash File write bkup RPL , Go to Service -> imei security-> simlock-> select make simlock rpl then hit update splock , aftre update simlock repair SD Data and write good pm file of 7210
via Super SD AUTH
hope ur problem will b solved
Next Time Use Search Button
The Following 2 Users Say Thank You to Ramzan For This Useful Post:
Old 08-03-2010, 12:19   #8 (permalink)
Member: 580966
Sonork: 100.1590311
Thanks Meter: 725
Hello,
Worked in my case i just test it on own handset .
Old 08-03-2010, 13:31   #9 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
via Super SD AUTH
bro problem same.....need more solution
Old 08-03-2010, 13:39   #10 (permalink)
Ramzan's Avatar
Member: 86597
Sonork: 100.1602630
Thanks Meter: 1,131
write 7210c rpl without NCP and try again
Old 08-03-2010, 14:01   #11 (permalink)
Member: 1359453
Thanks Meter: 2
Update SP Lock...
-Repair SD
-PM Auth
-write Full PM
-full factory reset all then chek
faisal
The Following User Says Thank You to expert mobile For This Useful Post:
Old 08-03-2010, 14:04   #12 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
i don't have pls upload here
thnx
Old 08-03-2010, 14:08   #13 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
hey guys....problem solved..
thnxx 4 support
mx-key is best tool in nokia
thnxxx frnds
Old 08-03-2010, 17:33   #14 (permalink)
jakoy's Avatar
Member: 14852
Sonork: 100.1608716
Thanks Meter: 503
how is the process i have same with your problem but not solve for me...
Page generated in 0.22353 seconds with 9 queries
