08-18-2010, 08:52 | #1 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 334773 Status: Offline Thanks Meter: 92 | nokia 7210c nokia restart flash after dead (answered) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0D80010E748D7D56EC72A4311B1776543499D50F ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Processing file: rm436__07.23.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.06 MB Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 19.12 MB CMT NOR area [00000000-000006BF] CMT NOR area [000006C0-0001FFFF] CMT NOR area [00040000-000BFFFF] CMT NOR area [000C0000-0013FFFF] CMT NOR area [00140000-0119FFFF] CMT NOR area [011A0000-0133FFFF] erased in 1 min 31.800 s Flash programming ... Error chk C7012D0103CD000010000000F1 RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00040000, Result: 0010 Flashing terminated with error(s) in 3 min 3.609 s RX Buffer: C7012D0103CD000010000000F172 UFS3 SarasSoft disconnected. |
08-18-2010, 08:57 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: saqi mobiles pirmahal pakistan Age: 36
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | Quote:
check your cable and retri | |
10-28-2010, 09:57 | #8 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Hell..... Bcoz i am devil_king Age: 37
Member: 696623 Status: Offline Sonork: 100.1601050 Thanks Meter: 526 | bro chek firmware version with product code .. if u write lower ver.. then it make problem and not start phone .. so try with higher ver... |
10-28-2010, 10:30 | #9 (permalink) | |
Freak Poster Join Date: Apr 2009
Member: 1003310 Status: Offline Thanks Meter: 28 | Quote:
Note: For reading configuration 5pin will not give you an issue the issue comes while u go ahead with actual process... | |
11-13-2010, 14:29 | #10 (permalink) |
Crazy Poster Join Date: May 2008
Member: 782309 Status: Offline Thanks Meter: 4 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9005(07-11-2010), 1.0.0.14948(07-11-2010) Processing MCU file: rm436__07.23.mcusw [BB5,BB5 ALGORITHM] size: 18.06 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1F70011390927D5678D8BE976856B20912DB3093 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 19.12 MB CMT NOR area [00000000-000006BF] erased in 0.859 s CMT NOR area [000006C0-0001FFFF] erased in 0.235 s CMT NOR area [00040000-000BFFFF] erased in 3.047 s CMT NOR area [000C0000-0013FFFF] erased in 0.250 s CMT NOR area [00140000-0119FFFF] erased in 1 min 1.203 s CMT NOR area [011A0000-0133FFFF] erased in 9.328 s Flash programming ... CMT PAPUBKEYS: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 (RAP Certificate 142 v.1) written. Programming completed in 2 min 39.735 s Processing PPM file: rm436__07.23.ppm_mr [BB5,BB5 ALGORITHM] size: 7.10 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1F70011390927D5678D8BE976856B20912DB3093 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Erase size: 8.62 MB CMT NOR area [01340000-01BDFFFF] erased in 40.453 s Flash programming ... Programming completed in 1 min 1.110 s Processing CNT file: rm436__07.23.image_mr_ny [BB5,BB5 ALGORITHM] page size: 128 K size: 6.63 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 1F70011390927D5678D8BE976856B20912DB3093 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 TransmissionMode: DDR&TX2 Erase size: 35.87 MB CMT NOR area [01BE0000-01F7FFFF] erased in 28.359 s CMT NOR area [01F80000-03FBFFFF] erased in 59.468 s Flash programming ... Programming completed in 53.438 s Total time for flashing process(boot+erase+write) was 8 min 47.406 s Flashing completed in 9 min 8.750 s only shows plz help |
