Old 05-02-2012, 08:42   #1 (permalink)
Crazy Poster
Member: 554609
Thanks Meter: 4
nokia 7210c security-test failed
Phone type: RM-436 (Nokia 7210 Supernova)
SW version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35931002660509-7
Product code: 0566807
Battery voltage: 4887 mV, current: 50 mA
Language Pack:
- not available.
SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK)
Camera config: NIMMIIIIRRFF094B2F01, ver: 002.010
MMC password: poshvari
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 359310026605097
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
hollo,bhother plz help 7210c contack service
Old 05-02-2012, 08:50   #2 (permalink)
akhtarmughal's Avatar
Member: 617073
Sonork: 100.1611349
Thanks Meter: 316
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
bro first repair sd area than write pm file 1 and 309 section
i hope your problem will bo sloved
or contact me in PM with team viewer ID
Old 05-02-2012, 08:53   #3 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
repair sd > write full pm
not solved? use SEARCH button, there are thousands similar threads...
learning by searching and trying bro...
br
Old 05-02-2012, 09:35   #4 (permalink)
Member: 207561
Thanks Meter: 820
mx key mx box can;t solve
Old 05-02-2012, 10:15   #5 (permalink)
Member: 807057
Thanks Meter: 16
use mx key.repair sd then repair simlock/update simlock
The Following User Says Thank You to surea For This Useful Post:
Old 05-02-2012, 10:26   #6 (permalink)
Crazy Poster
Member: 554609
Thanks Meter: 4
hi brother,my team viewer 7.............id 485 291 104 pass word 49p14m 7210c contack service plz help................................
Old 05-02-2012, 10:59   #7 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. your team viewer password is wrong.
Old 05-02-2012, 13:48   #8 (permalink)
Member: 577307
Thanks Meter: 58
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
use recover CERT button in IMEI tab. some time it works one phone recovered from sequrity test fail nokia 7201c
Old 05-02-2012, 13:49   #9 (permalink)
Cheater -Don't Deal with him-
Member: 1664659
Sonork: 100.1615261
Thanks Meter: 228
use cyclonebox & best bb5
Old 05-02-2012, 14:05   #10 (permalink)
Member: 1609044
Thanks Meter: 892
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
frist use ver son mobileEx 3.5 (rev1.6) 2 nd repair sd wite pm 1&309 do reset all 1000% ok
Old 05-02-2012, 14:14   #11 (permalink)
Crazy Poster
Member: 554609
Thanks Meter: 4
nokia 7210c security test failed.probleam slove in mx key sd area then write pm 1and 309...............good job thank a lot all bro good support
The Following User Says Thank You to afsar For This Useful Post:
Old 05-02-2012, 15:37   #12 (permalink)
Member deceased !!
R@SEL.NET's Avatar
Member: 670820
Sonork: 100.1583728
Thanks Meter: 1,348
do super sd auth then write modifyed pm(1&309 field).............
Old 05-02-2012, 15:59   #13 (permalink)
Member: 1715911
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Brother try cyclonebox
Old 05-02-2012, 16:02   #14 (permalink)
.::EXTREME::.'s Avatar
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,517
http://forum.gsmhosting.com/vbb/8166640-post18.html
Old 12-25-2012, 09:01   #15 (permalink)
Member: 697969
Thanks Meter: 8
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
bro just write full pm from other working only unmark section 1 unde pm308.i solved 3 pcs.
Page generated in 0.21324 seconds with 9 queries
