Old 12-15-2012, 11:53   #1 (permalink)
Javed ajmeri's Avatar
Member: 424082
Thanks Meter: 128
Arrow Nokia 7210C security test failed
I can't repair security test failed
i try all solutions (pm1-309/ super sd / recover certificate etc )
yet not problem solve.
please solve this problem(sx4 server erorr)
Old 12-15-2012, 12:23   #2 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
repair SD then repair simlock update simlock
mx key sd area then write pm 1and 309.
wbr ; tejaram
Old 12-15-2012, 12:55   #3 (permalink)
Member: 172261
Thanks Meter: 364
Better post your log here
Sent from my iPhone 5 using Tapatalk
Old 12-15-2012, 19:37   #4 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
3 Buttons Pmm SD Auth & Repair SD Use It & Post With Screen Shot
BR.
Arsalan gsm2000.
The Following 2 Users Say Thank You to .::MASTER ALONE::. For This Useful Post:
Old 12-15-2012, 21:27   #5 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Try this way.
Go to Service Tab > Click Load from File > Select Address:
C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-436.PM file,
Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result.
BR,
ZUBER
Old 12-18-2012, 07:57   #6 (permalink)
Member: 424082
Thanks Meter: 128
Arrow
Phone type: RM-436 (Nokia 7210 Supernova)
SW version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35931002230692-2
Product code: 0572571
Battery voltage: 4893 mV, current: 62 mA
Language Pack:
- not available.
SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK)
Camera config: NIMMIIIIRRFF094B2F01, ver: 002.012
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 359310022306922
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Scanning local SX4 Card ...
No SX4 Card found.
SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.5
Authenticating using [MX] security server ...
Connecting to server[main.mxkey.biz] ...Connection timed out
Connecting to server[main.mxkey.biz] ...Aborting operation ...
Operation aborted by user request!
Old 12-18-2012, 08:00   #7 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,220
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
No SX4 Card found.
contact me on yahoo see via team
Page generated in 0.15434 seconds with 8 queries
