Old 08-25-2009, 16:32   #1 (permalink)
Member: 125366
Sonork: 100.1602649
Thanks Meter: 108
Nokia 7210c show not enouf memory
i flash whit letes version but still same condition.
Old 08-25-2009, 17:02   #2 (permalink)
pallumobile's Avatar
Member: 659890
Thanks Meter: 263
Yes mate this is very common problem coming with the nokia 7210c. I also faces this problem twice before but haven't get the proper solution. I also format, flash with the latest ver but still the problem is same.
Old 08-29-2009, 09:31   #3 (permalink)
vodafoneserver's Avatar
Member: 617174
Sonork: 100.1622609
Thanks Meter: 579
i am wait 7 days but not solution ..........
Old 08-29-2009, 09:38   #4 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
Thanks Meter: 526
i have faced that problem before but i try to full flash its ok no erasing etc...fone ok and working fine
can play mp3 and videos as well....
Old 08-29-2009, 09:45   #5 (permalink)
hanif007's Avatar
Member: 665441
Sonork: 100.1670531
Thanks Meter: 603
1st make full backup
2nd full erase
3rd flash with skip erase
write modifyed pm with remove 308
& restore backup
problum solve 100% but phone was restart 3 or 4 minit in music
process in owner risk
try & post result................
Old 08-29-2009, 22:19   #6 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
2nd full erase
& restore backup
This type of solution is given by juniors.When i have full rpl back up not to worry about phone off problem.
As we know that bb5 rpl server is closed now,we dont want to take any risk.
Old 08-29-2009, 22:44   #7 (permalink)
gsm2start's Avatar
Member: 894719
Sonork: 100.1580092
Thanks Meter: 905
it seems hardware fault
i had this problem before and couldnt solve it
was fixed by the hardware eng
Old 08-30-2009, 05:09   #8 (permalink)
ehsas_ghum's Avatar
Member: 171512
Thanks Meter: 1,034
hi to all just downgrade yur set n yur problem is solve
plz post a reply if sucess bcoz i repair 2 set by downgrade thanks
Old 08-30-2009, 05:51   #9 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 3,374
dont erase ......bcz maybe not restored after erase
Old 08-30-2009, 05:54   #10 (permalink)
Imrankhan's Avatar
Member: 573962
Sonork: 100.1603021
Thanks Meter: 480
do not erase .
flash fone with latest firmware.
i fase this problem and solve by flashing.
nokia 7210c mic not working need solution rohit50 Nokia Hardware & Hardware Repair 22 08-25-2013 12:24
Nokia 7210c show not enouf memory aukonline Nokia Base Band 5 ( BB-5 ) 35 06-27-2012 05:09
Nokia 7210c charging not supported solution.tested by me.. mahbubalfa Nokia Hardware & Hardware Repair 13 09-30-2011 10:49
Nokia 7210c charging not supported infinitymobiles Nokia Hardware & Hardware Repair 3 11-11-2009 07:35
Nokia 7210c charging not supported klite31 Nokia Hardware & Hardware Repair 4 10-24-2009 05:33
Page generated in 0.28385 seconds with 9 queries
