02-08-2011, 07:56 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: jind
Member: 998896 Status: Offline Thanks Meter: 15 | nokia 7210c Updating SIMLOCK...error 0x14 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[11C000171E6D7C56E28644D74FE7F5F62A645424] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.5 Completed in 3.531 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_35*8*****8787_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... SIMLOCK_DATA corrupted! i m try sd repier.pm auth.eres flash restore imei .uopdate sp lock.make simlock rpl. but problam r same.. SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_DATA corrupted! |
02-08-2011, 08:08 | #2 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 405696 Status: Offline Thanks Meter: 148 | if ur phone showing logs like this SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted then DO FOLLOWING STEP 1. Backup RAP NPC Service > Imei & Security > Imei Rebuild: Section, Select RAP > Backup RPL 2. FULL ERASE Flash > Advance : untick safe ERASE > Erase Flash 3. Flash MCU,PPM,CNT 4. Restore IMEI Service > Imei & Security > Imei Rebuild > Restore Imei 5. Repair SPLock Service > Imei & Security > Simlock : Repair Simlock > Repair SPLock 6. Repair SD Service > Imei & Security > Imei Rebuild > Repair SD 7. Super SD Auth Service > PM > Super SD Auth 8. When super SD auth is done, write PM imediately. share ur log here then every body help u better |
02-08-2011, 09:12 | #5 (permalink) |
Member: 998896 Status: Offline Thanks Meter: 15 | SIMLOCK_DATA corrupted! Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Product: V 07.23 17-07-09 RM-436 (c) Nokia Using cached productData[11C000171E6D7C56E28644D74FE7F5F62A645424] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.5 Completed in 3.187 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_351962****787_SIM.RPL" Updating SIMLOCK...error 0x14 Reading Simlock info ... SIMLOCK_DATA corrupted! |
02-08-2011, 10:58 | #9 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | internet problem... reconnect your internet or stop downloading files if u r downloading something... just trying to suggest different solution than others... good luck bro... br |
02-08-2011, 11:13 | #10 (permalink) | |
Crazy Poster Join Date: Jun 2008 Location: Ukraine
Member: 798784 Status: Offline Thanks Meter: 6 | Quote:
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.5 Completed in 3.187 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-436_351962****787_SIM.RPL" | |
