Old 07-22-2010, 04:15   #1 (permalink)
Registered User
Member: 690799
Thanks Meter: 157
Nokia 7210s after full flash set not power on
[BB5,BB5 ALGORITHM] size: 6.15 MB
Supported RAP Ids: 010C192101013000, 0103192101003000, 030C192101033000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 26D0000D31F87C563CA612956954CEBD46A33EE9
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
TransmissionMode: DDR&TX2
Erase size: 8.62 MB
CMT NOR area [01340000-01BDFFFF] erased in 33.640 s
Flash programming ...
Programming completed in 48.985 s
Processing file: rm436__07.23.image_mb_128 as CNT
[BB5,BB5 ALGORITHM] page size: 128 K size: 20.27 MB
RAP Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 35.87 MB
CMT NOR area [01BE0000-01F7FFFF] erased in 0.094 s
CMT NOR area [01F80000-03FBFFFF] erased in 2 min 6.891 s
UCP page size is 128 K.
Programming completed in 2 min 43.281 s
Flashing completed in 11 min 35.657 s
Phone not responding !
Total time to process is 12 min 0.828 s
plz help where is problem?
The Following User Says Thank You to nakshatra For This Useful Post:
Old 07-22-2010, 04:30   #2 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,621
Try to flash with latest FW version using DEAD USB mood and post here.
Old 07-22-2010, 04:40   #3 (permalink)
Registered User
Member: 690799
Thanks Meter: 157
latest firmware is 7.23, i m using that.
above flashing report is fbus flashing. & there is no option for dead usb.
anyway
I tried also usb flashing , here is log
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Processing file: rm436__07.23.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 18.06 MB
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable,Battery back to device.
Insert Charger or Press phone's power button
Waiting for USB device ...
[ADL] Polling for ADL device
[ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 10D9616E
RAP SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
RAP EM0 ID: 00000295
RAP EM1 ID: 00000B22
RAP PUBLIC ID: 26D0000D31F87C563CA612956954CEBD46A33EE9
RAP ASIC MODE ID: 00
RAP ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
RAP ROM ID: 273F6D55DFAAF68F
[ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes
Nokia USB Flashing Generic ready.
[ADL] Update Server code succesfully sent to phone.
[ADL] Flashing CMT Update Server Data, UPDAPP: 0x4AD00 bytes
[ADL] Flashing CMT Update Server Data, PASUBTOC: 0x59700 bytes
[ADL] Timeout, no usb device found.
Flashing terminated with error(s) in 27.375 s
Old 07-22-2010, 06:33   #4 (permalink)
Member: 1217358
Sonork: 100.1605541
Thanks Meter: 156
than flash UFS box and try
The Following User Says Thank You to alpona_su For This Useful Post:
Old 07-22-2010, 06:50   #5 (permalink)
Ramzan's Avatar
Member: 86597
Sonork: 100.1602630
Thanks Meter: 1,131
First Make Bkup rpl , Full Erease ur Phone then Flash with latest firmware,write rpl
if phone power on then repair super SD and repair simlock
try it hope it will help u
Old 07-22-2010, 07:11   #6 (permalink)
..::\/\/::..'s Avatar
Member: 1294131
Sonork: 16919899
Thanks Meter: 579
yes br,
try your set is 100%ok
Old 07-22-2010, 07:14   #7 (permalink)
ahmad yousif's Avatar
Member: 764174
Thanks Meter: 259
DONT ERASE
remove camera from phone then reflash
it will work
then replace camera
The Following User Says Thank You to ahmad yousif For This Useful Post:
Old 07-23-2010, 04:08   #8 (permalink)
Registered User
Member: 690799
Thanks Meter: 157
I have already done above steps
1. full erase
2. full flash with latest firmware 7.23 (if any new firm. plz let me inform)
3. but after full flash set not ui defaults with ufs.
so there is no question for sd & repair simlock.
& I tried with removing camera. but no result.
any other tricks.
I already took rpl backup with ufs.
by mxkey there is problem for taking rpl backup.
Old 07-23-2010, 13:12   #9 (permalink)
Member: 764174
Thanks Meter: 259
TRY to flash it by dead usp
Old 07-23-2010, 13:25   #10 (permalink)
Member: 996590
Sonork: 57027
Thanks Meter: 16
try to flash with
rm436_CareDP_7.00_NDT_07.00_7210s.exe
Old 07-26-2010, 05:49   #11 (permalink)
Registered User
Member: 690799
Thanks Meter: 157
all tried but no solouiton
with jaf, full flash done, but at the end ,
FAST MODE finished!
Operation took 2 minutes 42 seconds...
Reseting phone...
Done!
Total time: 6 Minutes, 41 Seconds
DCT4/BB5 counter: 20
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
Old 10-03-2010, 16:29   #12 (permalink)
Member: 1342188
Sonork: 100.1607654
Thanks Meter: 129
first backup rpl then contact me on [email protected],,, on messanger-- [email protected]
Old 10-04-2010, 05:49   #13 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,516
Thats mean in your phone hardware problem present.
Just simply gentle rehot the pcb then check it.
Br.
Vijendra Saini.
Page generated in 0.19779 seconds with 9 queries
