Old 06-03-2010, 07:30   #1 (permalink)
Member: 535623
Sonork: 100.1586332
Thanks Meter: 21
nokia 7210s contract service
Phone Type: RM-436 (Nokia 7210 Supernova)
SW Version: V 07.23 17-07-09 RM-436 (c) Nokia
Imei plain: 35318003157708-6
Product Code: 0514950
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 353180031577086
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
try SUPER SD Auth
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Product: V 07.23 17-07-09 RM-436 (c) Nokia
Using cached productData[1EF0000D53247D56D2784D0C3974D6781C1167CB] ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
please help
"kathakunjo"
Old 06-03-2010, 07:55   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
have you ever repair SD before for this phone? if NO, then use PMM auth.
else,
1. repair SD
2. load pm file that contain 1+309 field, super SD auth, when done
3. write pm
Old 06-03-2010, 08:01   #3 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Originally Posted by gbluez View Post
hi,
else,
1. repair SD
3. write pm
super SD auth not working with 7210c contrac service
Old 06-03-2010, 08:56   #4 (permalink)
nepoleanl's Avatar
Member: 836540
Thanks Meter: 71
try pmm auth and reply
Old 06-03-2010, 09:02   #5 (permalink)
..::\/\/::..'s Avatar
Member: 1294131
Sonork: 16919899
Thanks Meter: 579
try sd repear...........
Old 06-03-2010, 14:15   #6 (permalink)
Member: 535623
Sonork: 100.1586332
Thanks Meter: 21
hi,
else,
1. repair SD
3. write pm
i will try many times. but not work .. please help...
thanks..
Old 06-03-2010, 17:07   #7 (permalink)
navin71's Avatar
Member: 101891
Thanks Meter: 277
tried more than 20 times but result same "security test failed"
Old 06-03-2010, 18:04   #8 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
backup rpl
rest npc
go to pm click erase pm
writ rpl then click recover cert
simlock> click splock info then tick make simlock rpl then click update simlock
repair sd
go to pm >tick load rfbb from server then click SUPER SD AUTH and writ pm
fullfactory&format
Page generated in 0.20142 seconds with 9 queries
