NOKIA 7610 phone stat-up faild. contact the retailer phone stat-up faild. contact the retailer Phone Type: RH-51 (Nokia 7610) SW Version: V 2006_wk41 11-10-06 RH-51 (c) Nokia. Imei plain: 35227*********** Product Code: 0517282 Language Pack: - not available. Imei net: 352273*********** Version: SIMLOCKLIB VERSION 2.29 Counter: 0/3, 0/10 CONFIG_DATA: 0040000005FFFFFF PROFILE_BITS: 8BE70008070028FF PLEASE HELP |
JUST GO IN IN IMEI AND SECURITY TAB AND SELECT SIMLOCK THAN MAKE TICK ON SIM LOCL RPL THAN CLICL ON Update splock ur problem will be solve. |
it is only for bb5. it is not bb5 phone. just format user area. all ok. |
ya i agree with u irfan bhai |
just manual formate & check |
Farmate but failed............. |
bro use formate and set ok 10000000000000000000 *+3+green butten +power screen show formateing compalate and set can b ok |
same problum ji......... |
6670 7610 3230 blank & stat-up faild solution -------------------------------------------------------------------------------- first of all this problem happend after wrong flash or u recive the phone with this problem and normal flashing with mcu and ppm not help to repair this problem so do next 1- with ufs box start to erase manual this adress start: 00000000 end: 00FFFFFF start: 02000000 end: 02FFFFFF start: 04000000 end: 047FFFFF this 3 adress will eras the 3 flash's and u will not lost ur phone imei 2- with ufs again erase start: 00010000 end: 0000FFFF start: 02000000 end: 00FFFFFF start: 02FC0000 end: 0286FFFF start: 02A00000 end: 0000FFFF 3- flash ur phone with latest firmware 4- write full pm to ur phone 5- unlock and format user area if ur blank phone (7610-6670-3230 ) the problem up to software by this solution will work 100% if the phone still the same so the problem now is a hardware and this we will look on it sooon br CELL ZONE |
Good work hope it will work for all |
pls send me 7610 updated pm ..... pls pls pls |
use .hwk.format ................... |
yah i have hwk .. n i do full flash... but problem is no opretor found .. pls helm me bhaijaan |
Any body help..6670 start up faild. it comes with displaying NOKIA 1st-after flashing----- it was same before.. 2nd-then formated manually by 3+*+green butten+power--------it was same before-- 3rd-Then changed its boot ic,- arises same problem------- any sussions ??????????????????????????????????????/ |
10000000000000000000000%%%%%%%% * 3 green + on power screen show formateing compalate and set can b ok |
