05-31-2013, 10:34 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: POLAND
Member: 27761 Status: Offline Thanks Meter: 54 | Nokia 8800 Arte killed by mxkey during flashing Also phone can't be flashed in DEAD Mode via phonenix this is log from mxkey 3.5 rev26: Code: MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: XXXXX Using device: USB Phonet and HTI, FW ver: 00.50, SN: XXXX Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: nmwcdc, ver: 7.1.32.84 Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) Reading Important data ... NPC_DATA is empty. SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_358645015XXXXX_PM.rpl" Processing MCU file: rm233__10.00.mcusw [BB5,BB5 ALGORITHM] size: 18.95 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 NOR page size in the phone is 128 K. Battery voltage: 3953 mV Phone type: RM-233 (Nokia 8800e-1) Product code: 0563491 SW version: V 10.00 - 28-04-09 - RM-233 - (c) Nokia LanguagePkg version: 0 - 28-04-09 - RM-233 - (c) Nokia - B Version from phone: 10.00 Version from file: 10.00 CMT BOOT ID: 0803000002010000 CMT PUBLIC ID: 16C0000EF16F7B562D61339F289C0ABB0DAB0C73 CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT PAPUBKEYS HASH: 35533D51D73D1D01227E11385E72D4AFDFAE6E7A Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR, asic:CMT Storage0: 0000 0000 - 0000 0000 [unused/removed] type: NAND, asic:APE Flashing CMT Update Server Data, UPDAPP: 0x47380 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2A74C2BA Verifying communication to device OK. Erase size: 21.12 MB CMT FLASH,NOR area [00000000-0001FFFF] erased in 0.010 s CMT FLASH,NOR area [00040000-000BFFFF] erased in 0.030 s CMT FLASH,NOR area [000C0000-0013FFFF] erased in 0.030 s CMT FLASH,NOR area [013C0000-0153FFFF] erased in 4.412 s CMT FLASH,NOR area [00140000-013BFFFF] erased in 50.310 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 35533D51 [RAP Certificate 70 v1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 2 min 23.521 s Processing PPM file: rm233__10.00.ppm_b [BB5,BB5 ALGORITHM] size: 5.06 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 6.50 MB CMT FLASH,NOR area [01540000-01BBFFFF] erased in 15.090 s Flash programming ... Programming completed in 38.794 s Processing CNT file: rm233__10.00_ISM_006.image_b_carbon [BB5,XSR 1.5] page size: 128 K size: 36.86 MB Supported Ids: 0103192101003000, 010C192101003000 Erase size: 35.87 MB CMT FLASH,NOR area [01EC0000-03F9FFFF] erased in 1 min 36.350 s CMT FLASH,NOR area [01BC0000-01EBFFFF] erased in 8.870 s Converting UCP blocks to 128 K. Flash programming ... Error while programming [00] at 0x00020000, Result: 0000 |
05-31-2013, 12:55 | #3 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 54 | no phone look like this: Code: Phone type: RM-233 (Nokia 8800e-1) SW version: V 10.00 28-04-09 RM-233 (c) Nokia Imei plain: 12345610654321-? Product code: 0563491 Battery voltage: 4793 mV, current: 118 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
05-31-2013, 14:44 | #4 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 54 | after write pm backup in rpl format i got this: Code: Restoring RF/BB DATA from backup ... Updating RF ...OK Updating BB ...OK Updating WARRANTY ...OK Updating PROD ...OK Updating BT ...OK missing NPC data in the RPL file, CERT write skipped. Updating PRODUCTCODE (0563491)... OK Updating PSN (MXH897560)... OK Updating HWID (1006)... OK Updating SIMLOCK ...error 0x1 Updating WMDRM_PD ...OK Phone type: RM-233 (Nokia 8800e-1) SW version: V 10.00 28-04-09 RM-233 (c) Nokia Imei plain: 12345610654321-? Product code: 0563491 Battery voltage: 4793 mV, current: 107 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
05-31-2013, 14:54 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,590 | Code: eading Important data ... NPC_DATA is empty. SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK BR |
05-31-2013, 15:09 | #6 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 54 | no phone works ok, no problems just need to flash it. i always used phoenix but i didn't had flash file v10.00 so i used mxkey to download and then to flash 8800 via usb i made full erase and flash via FBUS but this i've got now: Code: Module ver: 1.0.0.21719(09-05-2013), Library ver: 1.0.0.14397(09-05-2013) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 16C0000EF16F7B562D61339F289C0ABB0DAB0C73 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Processing MCU file: rm233__10.00.mcusw [BB5,BB5 ALGORITHM] size: 18.95 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 21.12 MB CMT FLASH,NOR area [00000000-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [013C0000-0153FFFF] CMT FLASH,NOR area [00140000-013BFFFF] erased in 4.863 s Prog.status for Asic CMT ... NOR: OK Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 35533D51 [RAP Certificate 70 v1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Prog.status for Asic CMT ... NOR: OK Programming completed in 1 min 57.235 s Processing PPM file: rm233__10.00.ppm_b [BB5,BB5 ALGORITHM] size: 5.06 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 6.50 MB CMT FLASH,NOR area [01540000-01BBFFFF] erased in 1.502 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Prog.status for Asic CMT ... NOR: OK Programming completed in 31.600 s Processing CNT file: rm233__10.00_ISM_006.image_b_carbon [BB5,XSR 1.5] page size: 128 K size: 36.86 MB Supported Ids: 0103192101003000, 010C192101003000 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 35.87 MB CMT FLASH,NOR area [01EC0000-03F9FFFF] CMT FLASH,NOR area [01BC0000-01EBFFFF] erased in 8.244 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Error while programming [00] at 0x00000000, Result: 0000 Warning: programming MMC failed, please check if MicroSD exist ! Programming completed in 20.139 s Total time for flashing process(boot+erase+write) was 3 min 30.620 s Phone type: RM-233 (Nokia 8800e-1) SW version: V 10.00 28-04-09 RM-233 (c) Nokia Imei plain: 12345610654321-? Battery voltage: 4863 mV, current: 108 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Code: Error while programming [00] at 0x00000000, Result: 0000 Last edited by PSG; 05-31-2013 at 15:14. |
05-31-2013, 18:10 | #7 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro., Already recommended, Backup all Important Data before Flash, You have Flashed with Untick Safe Flash, may be the reason, So no way then buy Factory RPL. BR, ZUBER |
05-31-2013, 22:51 | #8 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Dear PSG, I am sorry for you. This kinda fancy phone is based with RAP3Gv3 should be handled by FBUS. USB is recommended only for updating. Code: RPL saved to "C:\mobileEx\3.5\data\backup\BB5_358645015XXXXX_PM.rpl" I see you also using FBUS cable. Did you made backup with this cable too? The only FATAL mistake is that you erase this phone without paying attention to the backup you made. About error while flashing: Do not load cnt file for mmc. BR |
06-03-2013, 09:40 | #9 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 54 | i never flashed mxkey without SAFE Flash option enabled, this is standard info i allways use usb flashing via phonenix because mxkey could make errors just like now, but for this time i download files so didn't change to phonenix for flash i don't load cnt file just mcu+ppm+image i flashed many 8800 via phoenix and NEVER killed it by this app i have NPC, CCC,HWC backup + two RPL files containing PM fields made for backup before i made anything with 8800. but can't use this RPL to fix 8800 becasue mxkey display: Code: Updating SIMLOCK ...error 0x1 also i still can't flash FBUS this 8800 becasue for ISM file mxkey display this: Code: Error while programming [00] at 0x00000000, Result: 0000 this is quite expensive phone so you know what you did by your mxkey tool. Last edited by PSG; 06-03-2013 at 09:46. |
06-03-2013, 16:30 | #10 (permalink) |
Member: 73565 Status: Offline Thanks Meter: 5,062 | Try1: - backup rpl: select RAP. - erase flash: get addr > select all, do not mark safe erase. - reflash MCU only with FBUS - Restore IMEI MANUALLY, use rpl from 1st step above. - Repair SpLock - Repair SD Phone is now should alive (but blank) and security are OK. Flashing resurrection: Proceed full flashing by USB with phoenix. p.s; on any error when doing simlock: - Play some function on IMEI & Security > Simlock tab. It's old security, don't worry. Last edited by gbluez; 06-04-2013 at 02:06. |
06-04-2013, 15:36 | #11 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 54 | can't fix using recovery cert: Code: CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 16C0000EF16F7B562D61339F289C0ABB0DAB0C73 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 35533D51D73D1D01227E11385E72D4AFDFAE6E7A TransmissionMode: DDR&TX2 Begin Certificate Request ... [InternalErrorFault] CERT not found, Certificate is null or empty (case id=0xCE00) [InternalErrorFault] CERT not found, Certificate is null or empty (case id=0xCE00) [InternalErrorFault] CERT not found, Certificate is null or empty (case id=0xCE00) [InternalErrorFault] CERT not found, Certificate is null or empty (case id=0xCE00) |
06-04-2013, 15:48 | #12 (permalink) | |
Member: 73565 Status: Offline Thanks Meter: 5,062 | Your RPL attached here doesn't contain any RAP certificate. Are you sure you have good backup? Please read again post #8 above. Quote:
06-04-2013, 16:01 | #13 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 54 | backup which i attached was auto read via usb before i start flashing (with safe option enabled) i don't have any other backup because i just wanted to flash this 8800 nothing more and due to error during ISM file flash: Code: Error while programming [00] at 0x00000000, Result: 0000 mxkey don't want to create RAP backup in BACKUP section because NPC/CCC is empty i little tired so could you expand: "Fix IMEI first" |
06-05-2013, 07:45 | #14 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
You cannot come out from this problem, From your Logs, NPC Certificates not Backup in saved RPL, This only happens when one have not selected "ALL Section" while Backup RPL or only saved Simlock RPL, The Phone is Expensive, so you may try get Factory RPL without wait anymore for any solution. BR, ZUBER | |
06-05-2013, 09:24 | #15 (permalink) |
Member: 27761 Status: Offline Thanks Meter: 54 | Dear Zuber i told you i just wanted to flash that 8800 so i connect USB cable , SCAN, download firmware v10.00 for product code, check safe flash enabled and made flash.... and during ISM write i've got: Code: Error while programming [00] at 0x00000000, Result: 0000 i didn't planned to make anything else just reflash via USB , now i know i should use phonenix |
