05-05-2010, 15:30 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Age: 49
Member: 174853 Status: Offline Thanks Meter: 84 | nokia 8800 arte rm-233 usb flashing fail using mobileEx 3.4 i cannot flash 8800e-1 rm-233 using the latest mobileEx 3.4 here i post the log on window, kindly advice Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Processing file: rm233__10.00.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.95 MB Supported RAP Ids: 0103192101003000, 010C192101003000, 030C192101023000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 15C3C18B RAP SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] RAP EM0 ID: 00000295 RAP EM1 ID: 00000B22 RAP PUBLIC ID: 0D70000272B0465093197B2E0EC52EBDFCFFF4F1 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 RAP ROM ID: 273F6D55DFAAF68F [ADL] Flashing CMT Update Server Data, ULO: 0x3900 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, UPDAPP: 0x47380 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Flashing CMT Update Server Data, PASUBTOC: 0x55E40 bytes [ADL] Update Server code succesfully sent to phone. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, ID: 124D04AF [ADL] Verifying communication to device OK. Erase size: 21.12 MB CMT NOR area [00000000-0001FFFF] erased in 0.359 s CMT NOR area [00040000-000BFFFF] erased in 1.641 s CMT NOR area [000C0000-0013FFFF] erased in 1.531 s CMT NOR area [013C0000-0153FFFF] erased in 4.266 s CMT NOR area [00140000-013BFFFF] erased in 47.734 s Flash programming ... CMT PAPUBKEYS: 35533D51D73D1D01227E11385E72D4AFDFAE6E7A (RAP Certificate 70 v1) written. Programming completed in 2 min 20.625 s Processing file: rm233__10.00.ppm_x as PPM [BB5,BB5 ALGORITHM] size: 6.00 MB Supported RAP Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 6.50 MB CMT NOR area [01540000-01BBFFFF] erased in 16.797 s Flash programming ... Programming completed in 46.250 s Processing file: rm233__10.00_ISM_014.image_x_brown_128 as CNT [BB5,XSR 1.5] page size: 128 K size: 66.49 MB Supported RAP Ids: 0103192101003000, 010C192101003000 Erase size: 35.87 MB CMT NOR area [01EC0000-03F9FFFF] erased in 7.063 s CMT NOR area [01BC0000-01EBFFFF] erased in 0.703 s UCP page size is 128 K. Flash programming ... Error while programming [00] at 0x00020000, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 5 min 2.500 s |
05-06-2010, 09:14 | #3 (permalink) |
Member: 174853 Status: Offline Thanks Meter: 84 | log is Version from phone: 10.00 Version from file: 10.00 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0D70000272B0465093197B2E0EC52EBDFCFFF4F1 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 35533D51D73D1D01227E11385E72D4AFDFAE6E7A Reading RAP NPC (0x168 bytes). Reading RAP VARIANT (0x0 bytes). Reading RAP CCC (0x160 bytes). Reading RAP HWC (0xD4 bytes). Flash Imei: 35864501073203 NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35864501073203_BA CK.rpl" RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0D70000272B0465093197B2E0EC52EBDFCFFF4F1 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 35533D51D73D1D01227E11385E72D4AFDFAE6E7A Erase size: 21.12 MB CMT NOR area [00000000-0001FFFF] CMT NOR area [00040000-000BFFFF] CMT NOR area [000C0000-0013FFFF] CMT NOR area [013C0000-0153FFFF] CMT NOR area [00140000-013BFFFF] erased in 51.563 s Erase size: 6.50 MB CMT NOR area [01540000-01BBFFFF] erased in 16.188 s Converting UCP blocks to 128 K. Erase size: 35.87 MB CMT NOR area [01EC0000-03F9FFFF] CMT NOR area [01BC0000-01EBFFFF] erased in 15.469 s Erase completed in 1 min 29.765 s Flash programming ... CMT PAPUBKEYS: 35533D51D73D1D01227E11385E72D4AFDFAE6E7A (RAP Certificate 70 v1) written. Error while programming [00] at 0x00004000, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 16 min 47.719 s RX Buffer: B372 |
05-06-2010, 10:55 | #4 (permalink) |
Member: 174853 Status: Offline Thanks Meter: 84 | using JAF interface Version from phone: 10.00 Version from file: 10.00 Using device: POTATO BOX, FW ver: 01.B1 Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Rpl backup already exist (C:\mobileEx\3.4\data\backup\BB5_35864501073203_BA CK.rpl). Processing file: rm233__10.00.mcusw as MCU [BB5,BB5 ALGORITHM] size: 18.95 MB Supported RAP Ids: 0103192101003000, 010C192101003000, 030C192101023000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0D70000272B0465093197B2E0EC52EBDFCFFF4F1 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 35533D51D73D1D01227E11385E72D4AFDFAE6E7A Erase size: 21.12 MB CMT NOR area [00000000-0001FFFF] CMT NOR area [00040000-000BFFFF] CMT NOR area [000C0000-0013FFFF] CMT NOR area [013C0000-0153FFFF] CMT NOR area [00140000-013BFFFF] erased in 51.516 s Flash programming ... CMT PAPUBKEYS: 35533D51D73D1D01227E11385E72D4AFDFAE6E7A (RAP Certificate 70 v1) written. Programming completed in 13 min 52.796 s Processing file: rm233__10.00.ppm_x as PPM [BB5,BB5 ALGORITHM] size: 6.00 MB Supported RAP Ids: 0103192101003000, 010C192101003000, 030C192101023000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0D70000272B0465093197B2E0EC52EBDFCFFF4F1 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 35533D51D73D1D01227E11385E72D4AFDFAE6E7A Erase size: 6.50 MB CMT NOR area [01540000-01BBFFFF] erased in 16.093 s Flash programming ... Programming completed in 4 min 34.453 s Processing file: rm233__10.00_ISM_014.image_x_brown as CNT [BB5,XSR 1.5] page size: 128 K size: 66.49 MB Supported RAP Ids: 0103192101003000, 010C192101003000 RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 0D70000272B0465093197B2E0EC52EBDFCFFF4F1 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo_xsr15.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x26CB8 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 35533D51D73D1D01227E11385E72D4AFDFAE6E7A Storing certificate ...OK Erase size: 35.87 MB CMT NOR area [01EC0000-03F9FFFF] CMT NOR area [01BC0000-01EBFFFF] erased in 15.484 s Converting UCP blocks to 128 K. Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00044000, Result: 0000 Please try to use newer flashloader. Flashing terminated with error(s) in 20 min 26.891 s RX Buffer: C7012D0103CD00 |
05-06-2010, 19:43 | #5 (permalink) |
Member: 174853 Status: Offline Thanks Meter: 84 | is there anyone here know what is the problem with mx-key or this piece of software is a crap? you identify jaf box as potato flasher, but when i use free jaf c****ed it finish flashing procedure without any flaw (old jaf version) what is wrong with my paid mxkey?????? |
