Old 12-17-2009, 11:03   #1 (permalink)
rio_wp's Avatar
Member: 783663
Sonork: Ahmad Noer Asyadda
Thanks Meter: 32
Nokia 9300 flashing MXKEY so easy to use.
Nokia 9300 flashing with MXKEY
To repair damage nokia 9300 software is very easy to use and not complicated, try to follow these steps:
Please go to the folder C:\mobileEx\3.3\data\diver\nokia” Nokia_Connectivity_Cable_Driver”.
Then install to complete “Nokia_Connectivity_Cable_Driver”, later we can see these drivers in the folder
C:\Program File\Nokia\ Connectivity Cable Driver.
I use cable DKU2 and F-Bus cable RJ45, interface will only use the UFS.
Open Software MXKEY>GENERATIONct4>Model RAE-6>BUS Check, then enter nokia 9300 flash file.
“MCU” MCU Flash File : C:\Program File\Nokia\Phoenix\Products\RAE-6\RAE6_h56pr3.060
“PPM” PPM Flash File : None
“CNT” CNT Flash File : None
“ADSP” ADSP Flash File : C:\Program File\Nokia\Phoenix\Products\RAE-6\RAE6n4530.c01
“APE v” APE Variant File : C:\Program File\Nokia\Phoenix\Products\RAE-6\RAE6n4530.l123
“APE u” APE User Flash File : C:\Program File\Nokia\Phoenix\Products\RAE-6\RAE6n4530.u123
  Using device: UFS_USB V2.8 (c) SarasSoft 2007.
  Library version: 1.0.0.11443, Date: 23-11-2009
  Rpl backup already exist.
  Processing file: RAE6_h56pr3.060 as MCU
   [DCT4,MX/ORCA ALGORITHM]  size: 2.29 MB
  Supported Ids: 1130, 1131, 2141, 2140, 2142
  ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3]
   SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
  Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
  FlashID0: 00EC 22FA [Samsung K8S6415ETA,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
  FlashID1: 0000 0001 [unused/removed]
  ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
   Algorithm: m_amd.fia [MX/ORCA ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D0
  Performing Flash Authentication ...OK
  UEM ID: 005FFB6D:2984DA60
  Area [01000000-0100FFFF] erased in 0.578 s
  Area [01010000-0139FFFF] erased in 31.953 s
  [ADL] Pooling for Nokia ADL Flashing Engine ...
  [ADL] Device found : nmwcdnsuc\ADL Flashing Engine AVALON Generic, ID: 1B124B64
  [ADL] Message: ADL Server (c) NMP
  [ADL] ASIC ID: B470
  [ADL] MDOC ID: 0098 0007
  [ADL] Sending loader: omap1510_toshibamdocg3_7.adl
  [ADL] Flashing Update Server Data: 0x21330 bytes
  [ADL] Update Server code succesfully sent to phone
  [ADL] Loader ready.
  [ADL] Flashing APE Core: RAE6n4530.c01
  Area [013A0000-013EFFFF] erased in 2.953 s
  Area [017A0000-017EFFFF] erased in 2.828 s
  Flash programming ...
  Programming completed in 15.500 s
  File Processed in 1 min 4.609 s
  [ADL] Flash completed in 1 min 5.328 s
  [ADL] Flashing APE Variant: RAE6n4530.l123
  [ADL] Flash completed in 5.407 s
  [ADL] Flashing APE Userdisk Data: RAE6n4530.u123
  [ADL] Flash completed in 1.406 s
  Flashing completed in 1 min 41.875 s
  Phone Type: RAE-6 (Nokia 9300)
  SW Version: V3.06 20-12-04 RAE-6 (c) Nokia.
  Imei plain: 35432100125154-7
  Imei OTP: 35432100125154
  Product Code: 0522267
  Cellular System: GSM
  ASIC ID: 0x2142, type: 2
  Long Symbian SW version: 0010
  Bootcode: 000B00000017.00(00)
  Tertiary Loader: 002L28040619.00(00)
  Startup Screen: 401S17070601.00(00)
  APE Test MCU SW: 001T17070606.27(00)
  APE Core MCU SW: 001C17070606.27(00)
  APE ROFS Core: 001D17070606.27(00)
  APE ROFS Var: 020E17070606.27(00)
  Language Pack:
  - not available.
  Imei net: 35432100125154
  Version: SIMLOCK SERVER VERSION 50
  Provider: ALL Operator, Country: -
  Counter: 0/3, 0/10
  CONFIG_DATA: 0010100000000000
  PROFILE_BITS: 0000000000000002
  BLOCK 1:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
  BLOCK 2:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
  BLOCK 3:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
  BLOCK 4:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
  BLOCK 5:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
  BLOCK 6:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
  BLOCK 7:   1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
  Total time to process is 1 min 48.875 s
  FULL FACTORY... OK
  Completed in 1 min 8.437 s
  FULL FACTORY... OK
  USER DATA... OK
  LEAVE FACTORY... OK
  SERVICE CENTER... OK
  SOFTWARE UPGRADE... OK
  PRODUCTION TUNING... OK
  Reset User Code (to default:12345) ... OK
  Completed in 1.093 s
The Following 6 Users Say Thank You to rio_wp For This Useful Post:
not so easy to unlock s401i ZIYAAD STRYKER Easy-Unlocker 1 12-08-2009 08:06
how is the easy to use to unlock and flash tatoo Sony Ericsson 3 12-19-2008 07:26
Flashing W300i, which firmware to use so no camera problem? DFlash77 Sony Ericsson 0 02-23-2007 07:02
surprise free international calls and so easy to increase ur account odonto_hero Nokia Multimedia 0 07-20-2006 07:48
I need an easy to use Flash Reader atifprince Siemens-Benq RingTones and WallPapers 5 10-19-2003 12:55
Page generated in 0.27441 seconds with 8 queries
