Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 06-04-2012, 08:21   #1 (permalink)
hitesh2000's Avatar
Member: 365730
nokia asha 200
Nokia asha successfully flashed with mx box. how to recover superdongel invalid here is log:
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN:
Using device: USB ROM and HTI, FW ver: 00.50, SN:
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: nmwcdnsuc, ver: 7.1.32.73
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 31EC223F
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.37
EBL version: Quantum_Bootloader_10.37_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Processing file: rm761__11.56.mcusw
Downloading item CODE:rm761__11.56.mcusw_ebl_psi.fls, num block: 4, size: 25.25 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.359 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.344 s
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.515 s
Erasing area 0x40280000-0x41A7FFFE ...OK
Programming completed in 30.735 s
Checksum verified (0xC6C7)
Processing file: rm761__11.56.ppm_s
Downloading item CUSTackage_s.ppm_ebl_psi.fls, num block: 1, size: 6.65 MB
Erasing area 0x41A80000-0x421250FE ...OK
Programming completed in 8.734 s
Checksum verified (0xBF29)
Processing file: rm761__11.56.image_s_059J4N9_006
Downloading item CUSTackage_s_059J4N9.image.fls, num block: 1, size: 15 MB
Erasing area 0x421C0000-0x43E1FFFE ...OK
Programming completed in 20.140 s
Checksum verified (0xC8BE)
Total time for flashing process(boot+erase+write) was 6 min 7.906 s
Waiting for USB device removal ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 1355E24D
Verifying communication to device OK.
Phone type: RM-761 (Nokia 200)
SW version: V 11.56 26-03-12 RM-761 (c) Nokia
Imei plain: 35934604072330-0
Product code: 059J4N9
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
Camera config: 06150123008027, ver:
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35934604072330
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Market items is empty, please select the correct products path !
The Following User Says Thank You to hitesh2000 For This Useful Post:
Old 06-04-2012, 10:53   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Very simple Bro. Click Buscheck phone will enter Local Mode, change DCT4XGold to BB5. Now just click Super SD Auth & Repair SD. I think so.
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.20166 seconds with 11 queries
