Old 03-13-2012, 07:49   #1 (permalink)
Member: 1593286
Sonork: 100.1615210
Thanks Meter: 48
Nokia Asha 200 (ANSWERED)
Nokia Asha 200 RM-761 successfully Flash Mx_key
Update available
How to update: -
Open mobileEx.exe, Click "Synchronize Files" and
Click "Update" when popup dialog showed.
The Following 3 Users Say Thank You to fawad_new1 For This Useful Post:
Old 03-16-2012, 06:36   #2 (permalink)
AHMAD WAQAS's Avatar
Member: 808672
Sonork: 100.1612406
Thanks Meter: 82
Need Asha200 flash files
Old 03-16-2012, 07:03   #3 (permalink)
Member: 1280685
Thanks Meter: 52
Question Nokia Pinout Asha 200
How about Nokia Pinout Asha 200 (RM-761)?
Old 03-16-2012, 07:55   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,058
Ahmad,
You can use FiRe agent to download Nokia flash files. Here is the direction
MXBOX -How to use Fire Agent v1.1 (NEW SUPPORT ACCESS, OLD SERVERS ARE CLOSED)
Carros,
No need any pinout. You can use only USB cable.
Old 03-16-2012, 07:55   #5 (permalink)
..:: SONY ::..'s Avatar
Member: 1528548
Sonork: 100.1613286
Thanks Meter: 373
Check Screeshot Bro Flashing With Usb Cable
Old 03-16-2012, 08:54   #6 (permalink)
Member: 1593286
Sonork: 100.1615210
Thanks Meter: 48
nokia 200 flash file,,,,,,,,,,,,,,,
10.61.rar
Old 03-16-2012, 09:39   #7 (permalink)
Member: 1280685
Thanks Meter: 52
Question Nokia Asha 200 (RM-761)
Mxbox INFO Nokia Asha 200 (RM-761) SUPERDONGLE_KEY invalid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
SECURITY_TEST passed
Old 03-16-2012, 09:46   #8 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,058
SIMLOCK_TEST passed
Hot to repair SD with USB cable can be found here:
HTI On USB, what this box can do?
Old 03-16-2012, 10:07   #9 (permalink)
Member: 1280685
Thanks Meter: 52
INFINEON Phones are Supported for Repair SD Nokia Asha 200 (RM-761) in MXBOX via USB cable
Old 03-17-2012, 02:51   #10 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,058
Carroz,
- Please post your logs. Select DCT4, press scan.
- Start self test, post the logs.
Old 04-12-2012, 19:38   #11 (permalink)
praji's Avatar
Member: 563648
Sonork: 100.1594523
Thanks Meter: 87
successfully flashed
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.46
EBL version: Quantum_Bootloader_10.46_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI: 35934504371146
RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35934504371146_ back.RPL)
Processing file: rm761__11.56.mcusw
Downloading item CODE:rm761__11.56.mcusw_ebl_psi.fls, num block: 4, size: 25.25 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.328 s
Erasing area 0x40040000-0x4005FFFE ...OK
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.313 s
Erasing area 0x40280000-0x41A7FFFE ...OK
Programming completed in 27.672 s
Checksum verified (0xC6C7)
Processing file: rm761__11.56.ppm_mec
Downloading item CUSTackage_mec.ppm_ebl_psi.fls, num block: 1, size: 6.36 MB
Erasing area 0x41A80000-0x420DB47E ...OK
Programming completed in 7.469 s
Checksum verified (0xA9D8)
Processing file: rm761__11.56.image_mec_059J4L2_006
Downloading item CUSTackage_mec_059J4L2.image.fls, num block: 1, size: 14.50 MB
Erasing area 0x421C0000-0x43E1FFFE ...OK
Programming completed in 16.718 s
Checksum verified (0xBACC)
Total time for flashing process(boot+erase+write) was 7 min 15.344 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 207F2782
Verifying communication to device OK.
After Flash Processing ...
Phone type: RM-761 (Nokia 200)
SW version: V 11.56 26-03-12 RM-761 (c) Nokia
Imei plain: 35934504371146-0
Product code: 059J4L2
Cellular system: GSM
ASIC ID: 0x0000, type: 11
Ppm Id: MEC
Language Pack:
- not available.
Imei net: 35934504371146
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
The Following User Says Thank You to praji For This Useful Post:
Old 04-13-2012, 05:01   #12 (permalink)
Member: 772651
Thanks Meter: 1,489
what we chose in model section (6310i)NPL-1 .. why ?
Old 04-15-2012, 18:50   #13 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,058
He choose flash file manually, not by using market dropdown.
And one thing for sure, he knows what he do by manual - very important about this.
Old 04-24-2012, 11:06   #14 (permalink)
akadhitz's Avatar
Member: 1017750
Sonork: 100.1624716
Thanks Meter: 57
Hi,
I need pinout for Nokia Asha 200 RM-761.
br,
Old 04-24-2012, 13:42   #15 (permalink)
Member: 682736
Thanks Meter: 367
Originally Posted by akadhitz View Post
Hi,
br,
Only usb flashing supported at the moment...
To make this section clean please don't make alive old posts.
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
Page generated in 0.49806 seconds with 8 queries
