10-09-2012, 11:56 | #1 (permalink) | |
No Life Poster Join Date: May 2009 Location: spain
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | HTI fw 00.17, cannot update. Fresh install win7 32bit It is working fine on the cluster, just calculating final NCK that doesnt requiere any HTI update. Code: Using device: HTI Flasher Interface (WinUSB) Connection status: UHCI:HUB:USB 2.00 Full-speed Interface: MXBOX/HTI (Powered by MXKEY) OTP ID: 27E70606A00C4E530AB9624B040000F5 Boot ver: 00.07, Box SN: 000059A2 FW version: 00.17 HTI Flasher Interface (WinUSB) ready. Code: HTI Serial: 000059A2 HTI Boot ver: 00.07 HTI FW ver: 00.17 CARD Serial: C0803949 CARD FW ver: 00.20 Counter remain: 95.22% Licenses: 0 = True 1 = True 2 = True - Registered to: hugmax No antivirus, No firewall. I got the Code: Waiting for HTI in boot mode ... » Begin transaction ... Initializing HTI ... » End transaction (status: 3, Failed to read device info.) Quote:
I can try doing the update on a WinXp pc that I have. Will it work? guess we will find out after I try | |
10-09-2012, 12:34 | #2 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | I just did it on winxp Code: HTI Serial: 000059A2 HTI Boot ver: 00.07 HTI FW ver: 00.50 CARD Serial: C0803949 CARD FW ver: 00.20 Counter remain: 95,21% Licenses: 0 = True 1 = True - Registered to: hugmax thanks |
10-09-2012, 14:02 | #3 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
BR. Arsalan gsm2000. | |
10-09-2012, 14:32 | #4 (permalink) |
Member: 1038811 Status: Offline Sonork: 100.1585462 Thanks Meter: 974 | Thanks for your post, I already said that I solved my problem doing it on winXP and wanted support to close this, there is no further issue. but your post is appreciated. |
