07-12-2012, 11:20 | #1 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1231601 Status: Offline Thanks Meter: 13 | 5250 help me here full log MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0856E16 Using device: HTI, FW ver: 00.50, SN: 00005C74 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 04800119C69F00526B7870CAB2A90A2DFD73D305 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.2.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.2.0 revision: 2.0 size: 0x8B45D Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: CA158EAEE7D8D7A5B2E4907CB6BD0A9C2794D992 Processing MCU file: RM-684_30.0.002_prd.core.C00 [BB5,XSR 1.6] size: 88.14 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 165.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-0A55FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: Status reported bad blocks. Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: CA158EAE [RAP Certificate v1 269] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 4 min 2.734 s Processing PPM file: RM-684_30.0.002_prd.rofs2.V11 [BB5,XSR 1.6] size: 20.25 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 42.75 MB CMT FLASH,MuxOneNAND area [069A0000-0945FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 57.906 s Processing PPM file: RM-684_30.0.002_C01_prd.rofs3.fpsx [BB5,XSR 1.6] size: 3.46 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 17 MB CMT FLASH,MuxOneNAND area [09460000-0A55FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 10.015 s Processing CNT file: RM684_30.0.002_000_000_U001.uda.fpsx [BB5,XSR 1.6] size: 16.96 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 79.12 MB CMT FLASH,MuxOneNAND area [0A560000-0F47FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 49.329 s Total time for flashing process(boot+erase+write) was 6 min 12.609 s |
07-12-2012, 16:08 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Reflow Flash Rapidoyawe IC will solve it or again Reflash after Reflow is 100% Solution as per your Phone error: NAND: Status reported bad blocks. BR, Zuber |
07-14-2012, 12:57 | #4 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. See i highlighted in your logs: Quote:
BR, Zuber | |
5250 NEEDED for 3020 | blaiseid | ARM9 BASED M62 / M62+ | 2 | 01-09-2005 18:39 |
mw3026 5250,5374,5375,5376... empty fields | tibitech | Infineon C16X M51 & ARM7 M52 BASED | 1 | 08-30-2004 19:17 |
About field 5250 | florinmar | Infineon C16X M51 & ARM7 M52 BASED | 1 | 01-28-2003 20:44 |
How must CUT 5250 field for unlocking?(+) | Baza | Infineon C16X M51 & ARM7 M52 BASED | 0 | 02-24-2002 12:49 |
MC922 Field 252 Incorrect and 5250 not exits | B.H | Infineon C16X M51 & ARM7 M52 BASED | 2 | 11-09-2000 04:14 |
