Old 03-05-2011, 08:13   #1 (permalink)
Registered User
Member: 1437921
Sonork: 100.1668345
Thanks Meter: 13
Post nokia c1-01 how to flash with mxkey??? (ANSWERED)
how to flash nokia c1-01 with mxkey any solution ??????
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 304D3565
WriteDevice failed: Failed to read/write device
Old 03-05-2011, 08:21   #2 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 864
bro u must tickmark check X-GOLD then try it
Old 03-05-2011, 10:52   #3 (permalink)
Member: 1512913
Sonork: sUn seT oF lifE
Thanks Meter: 3
Thumbs down
dear same problem with me.....!!! and my cell is power off after hang
Old 03-05-2011, 10:56   #4 (permalink)
Member: 682736
Thanks Meter: 380
Nokia C1-01 is BB5 set but unfortunately MX Key is unable to do any action till date...
Old 03-05-2011, 11:10   #5 (permalink)
Member: 294245
Sonork: 100.1602405
Thanks Meter: 114
same to me but bb5 tool woking good
Old 04-17-2011, 12:07   #6 (permalink)
Member: 411034
Thanks Meter: 22
c1-01 is bb5 fone & i ca,nt see xgold click in usb mode with mx key
Old 04-17-2011, 13:28   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
repeat operation by using this version:
- download current version, click here
- do module update click here
The Following User Says Thank You to gbluez For This Useful Post:
Old 04-20-2011, 08:50   #8 (permalink)
shakeel145's Avatar
Member: 510445
Sonork: 100.1638301
Thanks Meter: 349
after update same result plz help mex key
Old 04-20-2011, 09:00   #9 (permalink)
Cheater -Don't Deal with him-
Member: 410574
Thanks Meter: 134
gbluez
yes.. no result after update. UB can flash 10000% tested c1-01 rm-607
Old 04-20-2011, 09:02   #10 (permalink)
Member: 410574
Thanks Meter: 134
http://forum.gsmhosting.com/vbb/f550...ailed-1249730/
Old 05-27-2011, 19:27   #11 (permalink)
Member: 1000967
Thanks Meter: 27
it seems this problem is bigger than i thought have tryed and am having the same problem aswell mx team need to fix
The Following User Says Thank You to recoshaa For This Useful Post:
Old 05-27-2011, 21:37   #12 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
hi, what fix?
i repost my own post here for you
hi,
hope this will answer to all C1-01 questions
USB Flashing
MXKEY Serial: [MxKey HTI FLASHER INTERFACE 0] - C0696666
Driver: NMWCD, ver: 7.1.32.62, NTMP ver:
Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011)
Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 26212134
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
 Boot mode: 0xCC
 EBL version major/minor: 2.3
 EBL version : Quantum_Bootloader_2.3_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6500000
Flash ID: 00EC 3012 [Samsung ]
Processing file: rm607__04.40.mcusw
 Downloading item CODE:rm607__04.40.mcusw_ebl_psi.fls, num block: 5, size: 25 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.561 s
Erasing area 0x40040000-0x4007FFFE ...OK
Programming completed in 0.769 s
Erasing area 0x40080000-0x4009FFFE ...OK
Programming completed in 0.574 s
Erasing area 0x400A0000-0x4019FFFE ...OK
Programming completed in 1.919 s
Erasing area 0x40400000-0x41B7FFFE ...OK
Programming completed in 32.976 s
Checksum verified (0xD471)
Processing file: rm607__04.40.ppm_x
 Downloading item CUST:package_x.ppm_ebl_psi.fls, num block: 1, size: 4.10 MB
Erasing area 0x41C00000-0x42019006 ...OK
Programming completed in 6.005 s
Checksum verified (0xBE9A)
Processing file: rm607__04.40.image_x_0595594
 Downloading item CUST:package_x_0595594.image.fls, num block: 1, size: 13.63 MB
Erasing area 0x42200000-0x43E5FFFE ...OK
Programming completed in 19.101 s
Checksum verified (0x971B)
Total time for flashing process(boot+erase+write) was 3 min 28.885 s
Waiting for device boot up ...
Device found: nmwcdc\Nokia C1-01 USB Phonet, PORT_ID: 434E537
Verifying communication to device OK.
Phone Type: RM-607 (C1-01)
SW Version: V 04.40 23-02-11 RM-607 (c) Nokia
Imei plain: 35700904550046-9
Product Code: 059F0V3
Battery voltage: 3979 mV, current: 102 mA
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
Imei net: 35700904550046
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
USB - USER CODE READ
Load market, do buscheck, service tab will be activated
Old 01-28-2012, 16:28   #13 (permalink)
.....::::GsmAdeel:::::.....'s Avatar
Member: 767472
Sonork: 100.1609877
Thanks Meter: 587
Originally Posted by gbluez View Post
hi, what fix?
hi,
USB Flashing
CPU: XGOLD 213
Sending EBL ...OK
 Boot mode: 0xCC
Language Pack:
- not available.
Counter: 0/3, 0/10
Don;t Try To Cheape Info Again Ok All
X-GOLD Option Only DC4 Series Not a BB5 series
Old 01-28-2012, 16:51   #14 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
no matter DCT4/BB5 selection, mobileex auto select it's loader should be use.
do you have any problem with this?
Old 02-27-2012, 17:32   #15 (permalink)
Member: 1443428
thanks for usefuul post
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
Page generated in 0.42574 seconds with 8 queries
