06-27-2012, 01:37 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: South Mrorocco Age: 49
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | Nokia c1-01 RM-607 contact service I have nokia c1-01 with contact service simlock data is corrupted Here is flashing log MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C08516B0 Using device: USB Phonet and HTI, FW ver: 00.50, SN: 000151E9 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: nmwcdc, ver: 7.1.32.75 Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14119(16-06-2012) Battery voltage: 3597 mV Warning battery voltage is less, phone might not detected after flash ! Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 2.5 EBL version: Quantum_Bootloader_2.5_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Processing file: rm607__05.40.mcusw Downloading item CODE:rm607__05.40.mcusw_ebl_psi.fls, num block: 5, size: 25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.438 s Erasing area 0x40040000-0x4007FFFE ...OK Programming completed in 0.609 s Erasing area 0x40080000-0x4009FFFE ...OK Programming completed in 0.391 s Erasing area 0x400A0000-0x4019FFFE ...OK Programming completed in 1.812 s Erasing area 0x40400000-0x41B7FFFE ...OK Programming completed in 40.141 s Checksum verified (0xC075) Processing file: 3B1498FC_rm607__05.40.ppm_c Downloading item CUSTackage_c.ppm_ebl_psi.fls, num block: 1, size: 3.72 MB Erasing area 0x41C00000-0x41FB8A26 ...OK Programming completed in 9.454 s Checksum verified (0x376C) Processing file: B850CE70_rm607__05.40_003.image_c_proximus_be_9g7t 6 Downloading item CUSTackage_c_proximus_be.image.fls, num block: 1, size: 11.25 MB Erasing area 0x42200000-0x43E5FFFE ...OK Programming completed in 21.312 s Checksum verified (0xD3EB) Total time for flashing process(boot+erase+write) was 9 min 7.734 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia C1-01 USB Phonet, PORT_ID: 25E42F22 Verifying communication to device OK. Phone type: RM-607 (C1-01) SW version: V 05.40 01-06-11 RM-607 (c) Nokia Imei plain: 35788904848861-8 Product code: 059B0W4 Battery voltage: 3567 mV, current: 117 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: C Language Pack: - not available. Master code: 3532604013 Camera config: NI00CS00000401022E05, ver: 001.004 SIMLOCK_DATA corrupted! And here is both backup rpl and full pm hope slove that problem becose costmer give me 10 euro if not sloved 10 euro will gose a way regards |
The Following 2 Users Say Thank You to ramoon20 For This Useful Post: |
06-27-2012, 03:01 | #2 (permalink) |
Member: 80599 Status: Offline Sonork: 1621236 Thanks Meter: 280 | Here is RPL restore and pm restore but same problem SIMLOCK_DATA corrupted! contact service Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.37 EBL version: Quantum_Bootloader_10.37_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 357889048488610 Updating IMEI ... OK Updating HWC (0596382)... OK Updating CCC (0596382)... OK Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia C1-01 USB Phonet, PORT_ID: 25E42F22 Verifying communication to device OK. Updating PRODUCTCODE (059B0W4)... OK Updating PSN (9A05085AI)... OK Updating HWID (2002)... OK Updating SIMLOCK ...OK Phone type: RM-607 (C1-01) SW version: V 05.40 01-06-11 RM-607 (c) Nokia Imei plain: 35788904848861-8 Product code: 059B0W4 Battery voltage: 3458 mV, current: 107 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: C Language Pack: - not available. Master code: 3532604013 Camera config: NI00CS00000401022E05, ver: 001.004 SIMLOCK_DATA corrupted! |
06-28-2012, 05:43 | #7 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Tanzania
Member: 161280 Status: Offline Sonork: 100.1616990 Thanks Meter: 82 | Quote:
http://forum.gsmhosting.com/vbb/f550...2-4-a-1497295/ | |
06-28-2012, 06:10 | #8 (permalink) |
No Life Poster Join Date: Nov 2006 Location: pakistan Age: 39
Member: 384949 Status: Offline Sonork: 1611265 Thanks Meter: 523 | edit pm 120 and open with notepad and slact all 3 and 8 number remove and slact 3 to 0 8 to 0 and write back but only working this conter rest problem to contact serves |
06-29-2012, 08:14 | #9 (permalink) |
Junior Member Join Date: May 2008 Location: Mactan Lapu2x Cebu PHILIPPINE
Member: 782484 Status: Offline Sonork: Ding Thanks Meter: 17 | Base sa V5.40 files na ginamit mo tol wala ako nakikita access sya base in your Phone Product code market 059B0W4 at ito lang na V4.40 ang nakikita ko available Version sya base in that code 059B0W4 in RM-607 EURA_AZ_MBLUE_AZEBAJAN at try mo tong firmware V4.40 na pra sa kanya talaga and simlock data file inside restore mo lng simlock sa MxHTI Box Tol and post result? C1-01 RM-607.rar |
05-15-2014, 07:02 | #12 (permalink) | |
Junior Member Join Date: Mar 2013
Member: 1895739 Status: Offline Thanks Meter: 1 | nokia 1-01 rm 607 Quote:
sir i have rpl backup , but i dont know how to reinstall rpl plzzzzzz tell me how to reinstall rpl file i m waiting plzzzzzzzzzzzzzzzz thanks advanceeeeeeeeeeee | |
