Old 04-22-2012, 10:30   #1 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
Nokia c2-01 restart (ANSWERED)
I flash same product code but same problem
phone show nokia then white light >again show nokia then white light same restart
show log here plz
mxkey [mxkey team hti flasher interface (winusb) 4], sn: C086af0f
using device: Usb rom and hti, fw ver: 00.50, sn: 00013a08
connection status: Uhci:hub::usb 2.00 (full-speed)
driver: Nmwcd, ver: 7.1.32.73
module ver: 1.0.0.20454(13-03-2012), library ver: 1.0.0.13962(12-03-2012)
processing mcu file: Rm721__11.10.mcusw
[bb5,xsr 1.6] size: 28.57 mb
supported ids: 0203192102004100, 020c192102004100, 0203192102024100, 020c192102024100, 0203192102044100, 020c192102044100
make sure usb cable, battery and charger are removed from device.
Insert usb cable, battery back to device(make sure to have fully charged battery).
Insert charger or press phone's power button(if flashing doesnt start automatically)
waiting for usb rom device ...
Waiting for usb rom device ...
Device connected: Nmwcdnsuc\nokia usb flashing generic, port_id: 36b34a03
cmt system asic id: 000000010000022600000001020c192102044100 [raps2 ver: Pa 4.x]
cmt em0 id: 00001051
cmt em1 id: 00001060
cmt public id: 1a20011309dc6140cf1a21f11a944630fa7d1bd0
cmt asic mode id: 00
cmt root key hash: 7b045400e1752022f9eb80b0dea9c65d
cmt rom id: 67e82268f29cea60
loading cmt secondary boot code
secondaryboot: Rap3gv40_2nd.fg [bb5] version: 11.14.0 revision: 3.0 size: 0x3ac0
supported ids: 0203192102004000, 020c192102004000, 0203192102024000, 020c192102024000, 020c192102004100, 0203192102004100, 020c192102014100, 0203192102014100, 020c192102014000, 0203192102014000, 020c192102034000, 0203192102034000, 0203192102024100, 020c192102024100, 0203192102034100, 020c192102034100, 0203192102054100, 020c192102054100, 0203192102044100, 020c192102044100
ebb5protocoltype: New
secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: Ram, asic:cmt
storage1: Ffff 0000 - 0000 0000 type: Mmc, asic:cmt
storage2: 0000 0000 - 0000 0000 [unused/removed] type: Flash,nor, asic:cmt
storage3: 0000 0001 - 0000 0000 [unused/removed] type: Flash,nor, asic:cmt
storage4: 00ec 0030 - 0000 0431 [samsung k5w1g13acm-dj60,1 gbits] type: Flash,muxonenand, asic:cmt
suggested algorithm: Xsr 1.6
loading cmt update server data
algorithm: Rap3gv40_xsr17_alg.fg [xsr 1.6] version: 11.14.0 revision: 3.0 size: 0x91bd2
update server code loaded.
Waiting for usb device removal ...ok
waiting for usb device arrival ...ok
device connected: Nmwcdnsuc\nokia usb flashing generic, port_id: 36b34a03
fur: Adding asic cmt as client ok.
Reading cmt npc (0x168 bytes).
Reading cmt variant (0x0 bytes).
Reading cmt ccc (0x160 bytes).
Reading cmt hwc (0xd4 bytes).
Reading cmt r&d (0x0 bytes).
Reading cmt partnerc (0x0 bytes).
Npc_data saved ok
ccc_data saved ok
hwc_data saved ok
rpl saved to "c:\mobileex\3.5\data\backup\bb5_35907504940860_ce rt.rpl"
cmt papubkeys hash: 8443ecd57d2edaddaadbad248f1b3b559e14d184
storing certificate [npc, ccc, hwc, r&d] ...ok
partitioning....
Partitioning complete
erase size: 37.69 mb
cmt flash,muxonenand area [00020000-000203ff]
cmt flash,muxonenand area [00060000-0009ffff]
cmt flash,muxonenand area [000a0000-0025ffff]
cmt flash,muxonenand area [003e0000-005dffff]
cmt flash,muxonenand area [005e0000-010dffff]
cmt flash,muxonenand area [01ec0000-01edffff]
cmt flash,muxonenand area [027c0000-02cbffff]
cmt flash,muxonenand area [077c0000-07b3ffff]
cmt flash,muxonenand area [010e0000-01ebffff]
formating partition ...
Flash programming ...
Cmt ada block sent
cmt keys block sent
cmt primapp block sent
cmt pasubtoc block sent
cmt papubkeys: 8443ecd5 [] sent
cmt rap3nand block sent
cmt updapp block sent
cmt dsp0 block sent
cmt mcusw block sent
cmt mcusw1 block sent
cmt genio_init block sent
cmt isa+dynsw block sent
programming completed in 51.125 s
processing ppm file: Rm721__11.10.ppm_mr1
[bb5,xsr 1.6] size: 6.41 mb
erase size: 8.87 mb
cmt flash,muxonenand area [01ee0000-027bffff]
flash programming ...
Programming completed in 11.375 s
processing cnt file: Rm721__11.10_001.image_mr1_ctv_in_9l9v3
[bb5,xsr 1.6] size: 18.96 mb
erase size: 75.06 mb
cmt flash,muxonenand area [02cc0000-077bffff]
Programming completed in 34.329 s
total time for flashing process(boot+erase+write) was 2 min 9.125 s
waiting for usb device removal ...ok
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
Old 04-22-2012, 10:33   #2 (permalink)
Member: 1540810
Sonork: 100.1627394
Thanks Meter: 161
Which version of flash file do you use
Old 04-22-2012, 10:44   #3 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
which version of flash file do you use
i use both ver
11.10 & 11.20
Old 04-22-2012, 11:34   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Use HTI FBUS, and try to apply this patch
ignore any difference logs / version. just an example
- if problem still remain, flash the phone once more. do you have this unit GOOD RPL ?
- if problem still remain, proceed to check phone HW.
Page generated in 0.20625 seconds with 9 queries
