03-21-2011, 20:47 | #1 (permalink) |
Freak Poster Join Date: Feb 2011 Location: http://www.**********.com/
Member: 1522914 Status: Offline Thanks Meter: 3 | e7 dead after flashing (ANSWERED) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 29DAF41E CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 2A3002192FD60344879E739ADACA6D53B560476A CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0068 - 0000 0131 [Samsung LH28F160BG] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 29DAF41E Verifying communication to device OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x1D8 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35486404108508_CE RT.rpl" CMT PAPUBKEYS HASH: 8EABFDA6B8A757034233978C16A93B892CE2D4FA Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 508.06 MB CMT MuxOneNAND area [00040000-0007FFFF] CMT MuxOneNAND area [000C0000-008BFFFF] CMT MuxOneNAND area [00DC0000-0FC7FFFF] CMT MuxOneNAND area [2E100000-3E5FFFFF] Formating partition ... Flash programming ... CMT PAPUBKEYS: 8EABFDA6B8A757034233978C16A93B892CE2D4FA (RAP Certificate v1 248) written. Programming completed in 18.070 s Processing PPM file: RM-626_014.002_12.01_Balkans_QW1_79.92_prd.rofs2.fpsx [BB5,XSR 1.6] size: 38.79 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 67.50 MB CMT MuxOneNAND area [0A580000-0E8FFFFF] Flash programming ... Programming completed in 5.120 s Processing PPM file: RM-626_014.002_00.01_79.92_prd.rofs3.fpsx [BB5,XSR 1.6] size: 4.80 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 19.50 MB CMT MuxOneNAND area [0E900000-0FC7FFFF] Flash programming ... Programming completed in 0.098 s Total time for flashing process(boot+erase+write) was 36.874 s Waiting for device boot up ... Phone not found, retrying ... anyone help pls? SERVIS MOBILNIH TELEFONA | OTKLJU |
03-22-2011, 00:24 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | hi, please load firmware only by market drop down menu. NEVERRRRRRR load it manually, unless absolutely know what you put there. reflash the phone completely. include MCU, PPM, and all the rest of it. - DO NOT tick language only. - DO NOT tick safe flash, since now it's dead. |
04-09-2011, 16:00 | #4 (permalink) |
Junior Member Join Date: Jan 2008 Location: New York Age: 34
Member: 694002 Status: Offline Thanks Meter: 8 | Number of Image Files: 4 Processing Image File : RM-626_014.002_79.92_prd.core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 593 Entry Point: 0x0201 Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-626_014.002_C05.01_MEA_79.92_prd.rofs3.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 2 Entry Point: 0x00EE Page Format : -1 MAX PAGE : 0x00002C00 Processing Image File : RM-626_014.002_33.01_MEA_I_LatinQwerty_79.92_prd.rofs 2.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 200 Entry Point: 0x00EE Page Format : -1 MAX PAGE : 0x00040000 Processing Image File : RM-626_014.002_U02.01_79.92_prd.uda.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 375 Entry Point: 0x00EE Page Format : -1 MAX PAGE : 0x00040000 AUTO SELECTED DEAD USB FLASHING... If Flashing DOES NOT Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly.. AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootRom Verified! BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000003 ID DWORD 1 : 00000226 ID DWORD 2 : 00010007 ID DWORD 3 : 600C1921 ID DWORD 4 : 02031104 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0A900215 ID DWORD 1 : 3CD50344 ID DWORD 2 : 673AAC7B ID DWORD 3 : 9AC0F4CD ID DWORD 4 : B7D47F76 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : E693EF0D CRC 1 : AC22615B START FLASHING RawLoaderExtract: Processing RM-626_014.002_79.92_prd.core.fpsx CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_2n d.fg Secondary Loader Sent... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0068 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 0020 -> Device ID : 0068 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0031 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 0020 Device ID : 0068 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 40000000 (1024 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader:C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\RAPUv11_XS R17_alg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 PAPUB Keys Hash : 8EABFDA6B8A757034233978C16A93B892CE2D4FA ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-626\ ImadeFilename: RM-626_014.002_79.92_prd.core.fpsx Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00020000 Spare : FFFFFFFF Num Partitions : 00000005 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00140000 Size : 02E80000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 02FC0000 Size : 0CCC0000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 0FC80000 Size : 1E480000 Partition 4 ID : 00000027 Attribute : 00000001 RW Start Address : 2E100000 Size : 10500000 Partition 5 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 3E600000 Size : 00400000 PARTITION_INFO_REQUEST_BB5 : 64012F5F00030000020000FFFFFFFF00000005000000030000 00020014000002E80000000000040000000202FC00000CCC00 0000000008000000010FC800001E4800000000002700000001 2E100000105000000000000A000000013E6000000040000096 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x57 (87) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x23 (35) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-0007FFFF 1 : 000C0000-008BFFFF 2 : 00DC0000-0FC7FFFF 3 : 2E100000-3E5FFFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x03000000 Format Info : 000000000000000A0000000000000002000000640018000000 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5004120B000300000400000007FFFF120B000300000C000000 8BFFFF120B00030000DC00000FC7FFFF120B0003002E100000 3E5FFFFF54 ERASE_REQUEST_BB5 : 5001192F00030000000003000000000000000A000000000000 00020000006400180000000000020000000100000000000000 0025 Successfully erased.. Total blocks to write : 593 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : SOS+PMML >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : LDSP >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS+CORE stopet on 8% please help me |
05-31-2011, 14:48 | #5 (permalink) |
Freak Poster Join Date: Jan 2008 Location: phone care
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | same problem brother..my mobile e7 was working well i just flash wrong i select c7 and flash now my mobile daid..i try to reflash with e7 but same ..light blinking near usb..software taking but at last no factory reset.i try to flash it many time but same any solution.\ |
05-31-2011, 16:47 | #6 (permalink) |
Banned Join Date: Apr 2008
Member: 762819 Status: Offline Thanks Meter: 232 | Dear go to MXKEY support area and download the correct Product code (which is written on the back side of you mobile phone near IMEI) flash files and flash it again. Maybe ur problem solves... ALL THE BEST . . . |
06-02-2011, 09:14 | #7 (permalink) |
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | thanx for reply borther.bro i try to find in mx support but there is stil not avable this model..i download it from ub support full packege i found my code same like my mobile when i select file its show 3 file when i select fourth file manugae that is with my mobile code its cant flashing with atf and mx key not support also i cant select in mx key .and there is no usb option .i try it with ub but same.........i flesh is wrong with c7 only..now i try all as i can but same no power..every time taking software but not factory set.and at last no power....................customer want new now..... |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
5110 5.24 locked all 4 locks after unlocking... | MCG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-07-2000 22:24 |
