05-16-2011, 17:26 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Burundi Bujumbura
Member: 750759 Status: Offline Sonork: 75101010 Thanks Meter: 169 | Nokia C3-01 with security code (ANSWERED) Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 57D1A89 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 0D40021351D50344BDB0AB9FAC7FA91354614BDF CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0098 0030 - 0000 0131 [Toshiba NAND-1G] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 57D1A89 Verifying communication to device OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35626804692070_CE RT.rpl). CMT PAPUBKEYS HASH: 5AA09885C97BF3B0F6783A6337506F9394F346EF Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 45.06 MB CMT MuxOneNAND area [00020000-000203FF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 5AA09885C97BF3B0F6783A6337506F9394F346EF (RAP Certificate v1 261) sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT LDSP block sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 6.578 s Processing PPM file: 5C8C0C44_rm640__05.68.ppm_c [BB5,XSR 1.6] size: 7.78 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 12 MB CMT MuxOneNAND area [020C0000-02CBFFFF] Flash programming ... Programming completed in 1.734 s Processing CNT file: 4BDCC6B5_rm640__05.68_003.image_c_ctv_de_9d8j6 [BB5,XSR 1.6] size: 37.36 MB Supported Ids: 0003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 66.06 MB CMT MuxOneNAND area [03340000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 8.406 s Total time for flashing process(boot+erase+write) was 47.609 s Waiting for device boot up ... Device found: nmwcdc\Nokia C3-01 USB Phonet, PORT_ID: 17B60362 Verifying communication to device OK. Phone Type: RM-640 (Nokia C3-01) SW Version: V 05.68 10-12-10 RM-640 (c) Nokia Imei plain: 35626804692070-1 Product Code: 059C8T8 Battery voltage: 4042 mV, current: 144 mA Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356268046920701 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN after flash the phone still have security code, i try with 12345 but not done, any solution? I need help |
05-16-2011, 19:01 | #6 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Green Forest
Member: 1316000 Status: Offline Sonork: 100.1624093 Thanks Meter: 348 | bro you can try this. read write user code in usb mode is easy. find and buy this resistor 1------3.3K 2------4.5K 3------5.1K 4------7.5k 5------10k 6------15k i use 3.3k remove phone battery, connect on of this resistor in BSI and GROUND point. insert battery and power on your phone. now your phone directly go in local mode. after local mode you can remove your resistor no problem. connect usb cable open software and do what u need. in my case i just make a touch in phone BSI and GROUND line in my resistor and press power button after phone local mode i remove resistor. |
The Following User Says Thank You to net.tarik For This Useful Post: |
05-16-2011, 21:11 | #7 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | on this part, phone should be powered up in local mode by usb. Quote:
BR | |
The Following User Says Thank You to gbluez For This Useful Post: |
